I have a couple of questions about my Maytag dryer. It has an ozone lamp and socket attached to a brace on the outside of the drum,and a ?? watt ballast bulb mounted behind the filter at the inside rear of the drum. Is the wattage forty watts,like my 56 Whirlpool? The lamp is burnt out,and I want to replace it. Also,why is the ozone bulb mounted ouside the drum?? Whats up with that?? It would be impossible for that lamp to shine on the clothing like that. I think this dryer was made in 1959.
Now for the second question. The dryer is electric,and has a short of some sort. When you touch the timer dial as the dryer is on,you can feel a slight trickle if you are barefoot. I am ok with that. However, I replaced the vent hoses on both dryers with new metal hoses today. The metal hose from the Maytag's exhaust brushed against the metal 220 volt outlet box while the dryer was running,and sparks flew!! I am NOT ok with that!!
I removed the back panel,after disconnecting the dryer.It was very clean inside,and I did not see any obvious shorts,like a bare wire,or terminal pushed against the cabinet,etc. One of the teminals from the 220 volt power cord was loose at the bakelite connector block on the rear of the dryer,and the bakelite was slightly charred from that. I tightened that,and reinstalled the back panel and tried the dryer out again. This time I pushed the metal dryer vent hose against the outlet box (with a piece of wood) sparks flew again,so I unplugged the dryer,and here I am!!
I did notice a ground terminal on the rear of the cabinet,that is not in use. On these "oldies" does that need to be connected even with the three wire 220 volt power cord?
Obviously this dryer is NOT safe to use in this condition.
Any tips from anyone with knowledge on the old school Halo of Heat dryers will be appricated.
Thanks,
Rick
Thanks,
Rick
