e2lgirl
Yesterday I purchased my first wringer washer. 1951 E2L serial number 131919 I had to travel 12 hours to get it. 12 hours to get home with it. ( in a snow storm to boot)
I think I made a mistake by laying it down in the bed of my pick up, (I put the canopy on because of the weather) the machine was secured down onto a heavy rubber mat, so nothing slid around.
When I got home to unload. I noticed some oil pooled on the inside of the leg of the machine. I also noticed the wringer part had worked its way off the machine. Nothing was broken, no parts laying around. When we unloaded the machine into the house we kept it in the laying position until I figured where the oil was coming from, we also put it in the house this way to give the washer a chance to warm up, (as temp hit-9*C) before doing anything to it.
Once in the house I realized the oil had come from the wringer attachment part.
Before standing the machine upright, I took a spatula and scooped the oil off the inside of the machine where it had pooled. I did this because I have no idea what kind of oil it is, so i figured putting it in a container and saving it was a good idea. Once I stood the washer up on to its castors, the mystery oil was running down the leg below where the wringer attaches. Not lots, just a couple table spoons. When I went to re attach the wringer, the wringer didn't seem to want to slide back on very easy so rather than force it. I stopped. I did noticed teeth around the edges and in the very centre where I was going to slide the wringer back into it was hard to see casue it was oily , but it seemed like the wringer part should be put in a certain way. I need to know is there a certain way the wringer gets lined when going back onto the washer part? Also if the oil came out of where the wringer attaches shouldn't I put some kind of oil back in?
When inspecting the electrical chord and plug in, I noticed the plug in is a three prong plug, but the thickest round middle piece has been sawed off. Im new to all of this, but I am pretty sure a person could see an electrition on the chord and plug subject, and get a new chord with a 3 prong (cause no one wants to be electrocuted doing laundry) plug and take out the old one and re wire the new one. But the question is: on what part of the engine or machine does a person do this, and don't say it cant be done. The chord has to wire into something. I would like to know where so I can replace it.
So in a nutshell.
-Where does the plug & chord wire into for replacement purposes?
-What type of oil do I replace the spilled oil with?
-How do I get the oil back in where it leaked from?
-Once I replace the oil, is there a trick to getting the wringer piece back on?
When I have all of this done, is there anything else I need to know before I fire this bad boy up to use it?
One more thought. I need a manual so I can identify what all the parts are and what they do, right down to the last nut bolt and seal. Where do I find one of these? I don't want the prissy housewife version. I want the down and dirty picture and lable version with all the trouble shooting stuff. I also need to know what kind of tools to go any buy.
Thank you in advance to whomever answers this thread, your help will be most appreciated.
So in a nutshell.
