1954 KENMORE STOVE/OVEN 220v - just North of LA
Roper
I don't think Roper made electric ranges until Whirlpool bought them out.I have yet to ever see an older Roper electric range. The range posted looks similar to a GE with a bit of a difference in style. The pushbuttons being the give away. however,Philco, Westinghouse and Gibson also had the pushbutton burner controls.I think it's a GE made to Sears specifications.If the burners are Corox,it's a Westinghouse. that's the first thing I'd look at to find out who made it for Sears. A Philco would have fatter burners.
Range..
It is I believe a Roper, it has Chromalox units, 7 heat pushbutton controls, instead of GEs 5 heat, these bake with bottom heat only.
Whatever it really is, it's beautiful, rare, and in even more rare shape, has all documents, and is an absolute steal at $100.
I'm surprised the ad is still up on CL. This one won't last.
Roper electric
Laundromat, Roper was making electric ranges as far back as the 20's. Do an online search for "Roper electric range". I know my Aunt Eloise had an early 70's Kenmore electric (Avocado) that was made by Roper. I think the Pink 50's model in the "Green Acres" kitchen was a Roper or Kenmore. I first thought it was a Hotpoint, but decided otherwise.
thanks circlew!!!! It's just that in all the ads I've seen and old magazine advertising I've read, none were on the Roper electric range.
I saw one of these in a very nice home near me several years ago at an estate sale. It was beautiful up close. Did you notice the Press-Toe openers underneath the two storage drawers for opening them? Note that it is a double oven range; the picture of the open oven door is the companion oven on the left side. I think John told me that it is possible to do something to enable a Roper oven to supply top heat during baking; maybe it was replacing the thermostat. This no doubt has an open coil broil element in the large oven. If the small oven is like the smaller, lower oven in Kenmore electric built-ins, it would have no broil element.
I personally think this is one of the most ugly stoves I've ever seen, but that's just my opinion. The smaller oven in my 1956 Philco has only one rod-type element, you put in the bottom socket for bake & the upper socket for broil. The lady I got it from said it baked wonderfully but didn't say which oven.
It must be sold already.......
I called and left messaged twice and send an e-mail... STILL no reply!
I just love it when people do NOT bother to delete the ad once the item sells.
Oh well.... not like I really needed (or wanted) it anyway! HA!
Kevin
Well, if it sold that fast -- as I predicted it would -- it's a good indication that the stove found a good home where it will be appreciated.
Year Newer
My Great Aunt had Sears stove a year newer than this. Pushbuttons acrossed the top, signal lights in the center to show which burner was on and the knobs along the lower edge for the two ovens and the griddle. It had a deep well and the pan storage was one large drawer with the toe touch release. The clock had a clear resin based cover that cracked and broke if you hit it with an pan or if the pan over the left rear burner was large enough to touch the face of the clock. Burners were fine with all high, outside high, inside high, all medium, inside medium, outside medium, all low, outside low, inside low or simmer, deepwell was good, griddle was excellent, oven was good for roasting but a terrible baker because all heat came from the bottom so items were pale and flat on top. It was an extremely dependable range finally getting the boot in the 70,s when they moved to town. If you rotated the oven control knob to broil and then back to the desired temperature it activate the broil unit for preheat. In later years Sears went to a fixed setting for preheat which made one likely to forget to reset the selector to bake.
GIBSON!
Not that it makes any difference now, but I think it is a Gibson made Kenmore. I say this due to the push - button burner switches with seven speeds. That's what my Gibson uses - simmer, very low, low, medium low, medium, medium high, and high. Wow! The switches ARE made by General Electric, though, so who knows!! It's a beauty!!
