1955 Ford Thunderbird in....TURQUOISE
My first car was a 42 Ford GPW Jeep, my second was a 41 Dodge closed cab weapons carrier 1/2 ton pickup so I learned to drive a manual trans early on. The Dodge had a 4 speed crash box with absolutely no syncros and indestructible square cut gears.
You had to double clutch it to manually synchronize the gears so I learned that as well. It also had the original floor push button to engage the starter. The jeep had one too but it had been disabled and moved to a spot below the key slot that was added to pretty much all of them once they were auctioned off after the war.
The Jeep had also been converted to 12 volt, the PW was still the original 6 volt system, though most were converted to 12 volt with the 6 volt starter still in place. They never seemed to burn up and of course turned over super fast which was helpful.
I prefer a automatic these days, much less work to drive and no clutch to burn up and replace though neither vehicle needed a clutch while I had them.
The '50 GMC has a separate starter pedal to the right of the gas pedal.  I have to be careful because with size 13 shoes, it's easy to depress the gas along with the starter, which can lead to flooding.  The starter will operate independent of the key.  It truly is an ignition switch and nothing more.  The linked video clip shows the procedure on a Chevy of similar vintage.   It sounds to me like it was upgraded from a 6 volt to a 12 volt system.  The Jimmy is still 6 volt and it doesn't crank anywhere near that fast.
And yeah, no syncromesh on that thing either.
How about those '50s cars from GM that you could start without a key?  It sure was a different world back then.
http://https//www.youtube.com/watch?v=QYUBtzHTEEA
Maybe we should have started a new thread about vintage cars
I have to admit I do love to ask you folks questions and get an answer I can understand and I can say I recall only ever seeing one car my Father owned it was a 50's Wolsely 444 he had before a 666 which I learnt later meant it was a 4 cylinder 44 horse power and so on it was a huge black car that was shown on TV as a police vehicle with a silver bell they rang not nearly as fun as your 50's police cars. But back to the one we had it had bench seats with a armrest in the middle on which I used to sit as I was too small to see over the dash ! No need for car seats back then nor seat belts it didn't have any. When we sold the family home I cleared the garage out and found books about Wolsely's and parts which someone bought for a restoration they were doing. Dad had to sell the big black beast because Mum was learning to drive and refused to drive it because it had " 4 on a tree " as you put it lol so it was got rid of and a more boring Morris 1300 with new hydrolastic suspension in British racing green and no armrest so a cushion had to do instead :) Oh my how the mind remembers all this is amazing....!!!
Thank you all for clarifiying for me Austin
