1956 Filtrator Dryer
frigidaireguy
Feb 1, 2007
596
Wiston-Salem, NC
 I'm having a problem with my '56 Filtrator dryer. First off I have to give the drum a "boost" before the motor will start.  It now starts and runs for 5 to 7 minutes and shuts off.  What would cause this and what should I do to correct it.  Thanks for any help.
Bob
Starting Cap ...
Replace the starting cap first. This can cause this very issue and is a cheap test. Besides if you end up replacing the motor, replacing the start cap is a good idea at the same time. Check the centrifugal start switch for proper operation. Also check wire connections everywhere associated with the motor for corrosion.
Well heck .....
No cap. So they used a secondary field winding 90 degrees out of phase to the primary for starting. I remember playing with one of these kind of motors in engineering school back in the 80's. I always wondered why they would go with another added winding and a start switch vs just a cap.
Most US Home Laundry Motors Are Split-phase Induction Motors
They use a separate start winding usually controlled by a centrifugal start switch with some using a magnetic relay.
They use this type of motor for its high starting torque, they are also reliable and quiet running, major down side is very high current consumption.
90% of AWs, dryers and even wringer washers built over the last 80+ years use this type of motor, maybe about 10% also had an added start capacitor to add even a little more starting torque.
John L.
