Whirlpool drum belt
maytag85
May 11, 2017
3,281
Sean A806
Does anyone happen to know what the part number is for the pre 1966 Whirlpool dryers? Just wondering since the belt on mine is probably a number of years old and has a tendency to squeak a little upon startup, quiets down after 5 minutes of running.
I believe John mentioned the older drum belts are a different length compared to what they were using in 1966 awhile back if memory serves correctly.
Whirlpool drum belt Pt#s, 3 rib 337019 or the HD 4 rib # is 337555, the 555 was superseded the 3 rib belt but if you can find the 555 it does not squeal as much with very heavy loads.
Around 1969 WP switched to the thinner mini poly-bee belts that all makers use to this day which grip better and tend not to squeal much or even at all under very heavy loading.
John L.
