1956? MAYTAG GAS DRYER - MINNEAPOLIS
What an awesome find!
It looks so well preserved.
Thanks for the scans and pictures of the dryer with the back taken off.
Will you be using this dryer? I bet it would be great with towels and heavy fabrics.
Brent
Awesome Video!
How long did it take to cycle the burner off the first time?
I love this dryer!
Brent
Didn't pay attention to how long before the burner cycled off.
I did dry two loads of laundry in it and I have to say that I'm impressed! It dries HOT and relatively fast. A load that would take 60 minutes in the HOH was dry in 50 in this dryer. And the towels seemed fluffier. Maybe that's just because that's what I wanted to believe but I think it's true. There also seemed to be the faintest "filtrator-esque" smell to everything. Mind you, there is no ozone lamp on this dryer. Yet.
Very interesting Mark about the drying performance.
I find the burner set up is like commercial coin op machines.
I wonder why manufactures quit using this type of set up, with the drum that is perforated. I am sure it had something to do with cost.
You found a gem!
Brent
1956 Maytag Gas Dryer Burner operation
Thanks for posting the video of the ignition sequence Mark.
Maytag and many other gas dryer makers used this same system for many years, WP-KM used this system through 1963.
When you first start the dryer the pilot valve coil is opened and the Platinum 2 1/2 volt glow coil are energized, this lights the pilot flame which starts heating a mercury filled sensor bulb that in centered in the pilots flame. Once the mercury filled bulb is hot enough to flex a diafram and push a switch at the other end of the sensor to the hot position it then completes a circuit that allows the second and main gas valve to open and 18,000 BTUs worth of gas flows to the main burner.
These systems were fairly relibible and most gas dryers left the polet flame burning the whole drying cycle and just cycled the main burner. My friend Bob in Ohio found this same dryer last year and after fixing a few things on it has been using it as one of many machines he has.
The issue of the standing pilot in the HOH dryer has been discussed here before. I'm not sure that cost was as big of an issue as PERCEIVED reliability issues by the service techs in the field. I really don't know if there were many issues with the electric ignitor systems in the field, but the pilot light is certainly simpler!
Even after
Having such terrible luck with Maytag products, and really hating them...I have to admit, they are really well built and beautiful.Im glad they are being preserved.
I don't have a definitive answer for you, but perusing the trove of Maytag service and promotional literature that I have I'm going to make some guesses:
C = "conventional" dryer, flowing air that requires an exhaust vent
W = "water" dryer, a condensing water dryer that is not vented, but requires a cold water supply and drain
B = I have no clue
Kenmore71
I almost got a early 60's Maytag A902 set, but someone beat me to it. The dryer was not a Halo Of Heat, but it was a push button electric version of your 1956 Maytag gas dryer. I don't have that big of a collection, but I do have a early 80's Maytag A810 set, and I also have a mid 80's Lasy Kenmore portable belt drive washer and dryer.
