1959 GE Range does Thanksgiving!
The aroma wafting upstairs should make the house smell absolutely fantastic!  Hats off to you, and the '59 GE range.
You should remove the cover over one of the rear surface units while using the oven. The oven vent is under one of them and needs to be able to release the moisture somewhere other than under the whole cooktop where it will cause all kinds of trouble.
