The Maytag A606 I acquired back in March I only paid $30 for, and the washer worked on the first test other than adjusting the water level switch, and that’s was it for the washer.
Now the matching DG606 dryer I converted to a DG306 timed dryer needed a lot of work. It hadn’t been serviced or had the lint cleaned out in 46 years, and while the drum turned with little effort, I took everything apart and cleaned it up as much as I could. I had to do painting since it had some rust from the constant burning pilot light, and I had to replace all the felt seals since the outer felt seal was pretty much toast around the air enters the front of the drum.
