1960 Filtrator back in service
kenmore71
Bronze Member
Sep 20, 2010
1,724
Minneapolis, MN
Earlier this weekend I was visiting Swestoyz (Ben) down in Waterloo and we spent some time cleaning up and doing some rewiring work on a beautiful 1960 Frigidaire Custom Imperial Filtrator. Cosmetically it was in quite nice shape, there was just a bit of wiring work that needed to be reworked. Here it is with the back off and Ben is finishing up some wiring work.
Close-up of the timer dial.
1960 was either the first or second year of an automatic dryness control on a Filtrator.
It was a thermostatic type control.
The timer motor operates whenever the heater is "off".[this post was last edited: 2/5/2012-20:45]
Close-up of the other side of the console.
This looks fancy, but all it really is a complicated looking thermostat control indicator.
The buttons move the selector tape up and down WHILE it adjusts adjust the thermostat setting.
The temps. that Tech-Talk give are as follows:
Regular: 200 degrees
Bulky: 187 degrees
Sprinkle: 175 degrees
Wash & Wear: 150 degrees
Delicate: 125 degrees
Air fluff: no heat
Now, remember, that because of the way a filtrator works, temperatures can be much higher without fabric damage since clothes are essentially "steam-dried."[this post was last edited: 2/5/2012-20:46]
1960 FRIGIDAIRE CUSTOM IMPERIAL DRYER
Fun dryer Mark and Ben thanks for sharing your experiences with it. Tom and I have this Filterater and everyone from 1950 on that Frigidaire built. This is only the second year for auto dry, In fact very few manufactures had auto dry settings until about this time. In my experience using these dryers they dry fairly well if you have the temperature set at hi or close to it, at the lower temperatures they get very slow. These dryers operate at higher temperatures because they will not dry quickly at normal temperatures. And indeed in spite of drying in a steaming environment once the moisture is gone the clothing will reach 200 degrees+ and you can easily ruin delicate clothing in these dryers if not used carefully and properly.
 Ben I will be interested to here how you like using this dryer.
I have been fascinated with Filtrator dryers since I first learned about them a few years ago. This was my first experience "inside" of one. They are a very curious appliance and, in certain applications, can be a very efficient appliance. I can really see an advantage to using these dryers in northern climates in the winter where the heat and small amount of moisture that is produced by the operation of these dryers STAYS in the house instead of being vented outside along with already heated household air.
I would have LOVED to have had one of these dryers to sit in front of as a young child in our drafty 1916 farm house during the 1970s energy crisis!
At the same time, I can see how problematic one of these could be in an unairconditioned house in Houston in July.
Condenser dryers
Mark I too only use these in the colder months of the year, can you imagine using one of these when the central A/C is running. Interestingly when I compare just the electrical power use of a air-cooled condensing dryer [ I have compared 1950s and my 1962 Frigidaire CI dryer, and a 2000 Asko ] to just a regular 29" WP or KM electric dryer, the condenser models are not only far slower and dry far hotter but also use 25% more total power. I have never tested our old 1956 MT water condensing dryer for power consumption, I will have to do this sometime.
I have this same dryer and I love it ! It looks awesome....I was wondering did you find them as a set or individually? I have been looking for the matching washer but no luck....any suggestions where I might be able to locate a matching washer? Your set is awesome...This is truely my favorite Frigidaire set ever ! I have both owner manuals for the washer and the dryer ..
In the first picture
Note the spirnkler hose going in through the middle of the tub shaft. Inside the tub, you will see a little white knob in the middle of the drum back with a little hole for the sprinkler water to drip on the load. Water is added to the "ash tray" in the control panel. The sprinkler drawer is very reminiscent of the automobile ash trays of the time.
Note the belt switch on the pulley slider assembly with wires going to the heating element. If a belt breaks, the heat is shut off and even with that switch, we have seen Filtrators with terrible drum damage where the drum stopped and the portion of the drum that was apparently in front of the two 2200 watt heaters was warped and had porcelain damage. Maybe the belt did not break, but something else stopped the drum like the cover over the rear clean out port coming out and clothing escaping and lodging between the cylinder and the rear of the chamber.
I really love this design. The seperate "Control Dial" seems very futuristic looking to me, very googie!
I'll admit I really like this style, with the seperate dial for the timer. Too bad that this kind of style went away by the 70's.
According To My GM/Frigidaire Dryer Manual
There were several incarnations of Filtrator dryers that worked on 120v so am going to have to keep my eyes peeled. Think it would be kind of fun to have a larger drum than my vintage Whirlpool portable and about 300 more watts of heating power.
Ages ago remember one of those Euro combo front loading W/D units a friend had. IIRC that machine used water for condensing and managed a small load in a decent amount of time. Since they lived in an apartment building using all that water to "dry" laundry didn't phase her none.
120 volt Frigidaire Filterator dryer
Tom and I rescued a TR-61 20+ years ago that I still have and use at times in the winter. It was exactly the same as the 240 volt TR-60 except it had one 1700 @ 120 volts instead of having two 2200 watt @ 240 volts. It is very slow but not as slow as trying to run the 240 V model on 120 as that would only give you 1100 watts of heat. These 120V models were made throughout the 1950s and they could be fairly easily converted to 240Vs by installing the 240V heaters, all the wiring was already in place and the same.
If anybody is looking at the auto dry settings and wondering why Delicate is between Regular and Bulky instead of right near the end of the automatic cycle like in a GE dryer, it is because of the 125F temperature setting for delicates. The dryer heats to 125F faster so not only does that make the timer motor start running sooner than it does at the higher temperature settings but, as John said, at the lower temperature the drying is slower. That is because there is less temperature differential between the room temperature and the temperature inside the dryer so condensing the moisture is harder. Filtrator dryers evaporate moisture far faster than they can condense it. I remember how each time I would clean all of the lint out of the outer tub, the first load would dry really fast and water would condense so fast that the Filtrator apparatus could not quite handle it so it would leak onto the floor, like a puppy. While it would defeat the purpose of the machine, I have often wondered how fast one would dry outside in the winter. There is all of that empty space on the right side of the Filtrator cartridge where a refrigeration coil could go to chill the air passing over the Filtrator. You would still have the waste heat, but maybe faster drying.
In case you are wondering about drying wash'n wear, you have to pull the Filtrator cartridge out a couple of inches to the wash'n wear mark on it. This does not make a linty mess because those fabrics are not linty like cottons, although you have to clean any lint off that is on the cartridge before starting the w'n w load. Having the cartridge pulled out allows for more air flow through the drying chamber which means a better cool down at the end of the cycle and the last 10 minutes are a cooldown on the timed cycle.
