1960's Hotpoint Range Repair
archgirl
Oct 31, 2018
0
Scottsdale, AZ
I have a very cool 1960's Hotpoint Range. The oven portion (both broil and bake) have stopped working. The cooktop works fine. Does anyone know where we can find parts to repair this range. The Serial Number on the Range is JF 64177. I have attached photos and would love the help. We want to fix it and really don't want to have to replace it.
This may be a really easy 'fix'... If the clock and timer are no longer working on the range, you may have slipped one of the dials into delayed cooking mode. If there is a dial somewhere on the clock and timer that has a setting called 'MAN' or Manual, turn the dial to this position, then check the oven and broiler.
This is a common problem with older ranges - first time it happened on a 64 Kelvinator I used to have I freaked out... Then I remembered a friend who had a beautiful Frigidaire wall oven that had this 'problem'!
