1961 KitchenAid Superba VariCycle: Re-finishing Questions
backintime
Active member
Jan 4, 2015
27
Mass
Hi,
I am restoring a 1961 KitchenAid Superba VariCycle Dishwasher and I would like some feedback as to refinishing the interior surfaces. Per the original brochure, the interior had a porcelain coating, but the very thin coating has literally turned to powder and can be wiped of with steel wool. What is the most durable modern coating for the interior surfaces? Powder coating? Automotive grade base coat/clearcoat? Please advise.
Thanks
Mike
I have the same issue with my KDS-14 and I haven't done anything to it yet! So we're at least two waiting for answers! A friend of mine has used white paint from POR-15 to repair a washing machine tub and he had a great result but I also wish I could get something with the blue speckles. I also thought about automotive epoxy primer and paint spray painted in but I haven't tried anything yet! I'd also need to find a new door gasket for mine.
Easy and not so easy fixes!
As far as the door gasket is concerned, you can use the same gasket that was used on the KD15,16 and 17 series doors and will have to trim it as they are longer. I always recommend replacing the small stainless clips that retain the gasket in place. Put one on every screw and the gasket will fit really well and retain its shape.
If you cannot find anyone who has the blue gaskets, you can use the Hobart gasket which should still be a beige/ yellowish gasket. The part number for the gasket is 00-121030-00002 and the clips are 00-024677. The gasketis sold individually @ 23.06 each but the clips are sold as a min qty of 10 to a bag @ 2.35 each
You can purchase them from any local Hobart office or go to the link below and you can purchase them at the e-store directly.
As far as the tank surface goes, All I can say is that many years ago when the original UM machines were built, they had porcelain tanks which would wear out and I know that some of them were repainted with a good quality, marine epoxy paint. I cannot vouch for how long it might last but it may be worth a try. I suppose you should look for something that is non-toxic for obvious reasons. The only other choice is to keep your fingers crossed and hope to find a 14 out there that is in great condition.
http://thesmartpartsestore.hobartservice.com/
So does anyone have an opinion on the re-finishing? Powdercoat? Basecoat/Clear?
I'd have to think either would hold up well considering vehicles endure harsh winters/weather for quite some time.
I'd recommend a product called White-Coat - it's made by the same folks who make POR15 (a rust paint that is used in marine and other applications);  it's not cheap and I'd caution anyone using it to not mix up a large batch when using it.   Also, the surface to be repainted may need to be roughened for best results.  You may not be able to find this everywhere, but you can order it on-line.
I used it on a 1966 Inglis washer tub two years ago - the machine is being used regularly and I am amazed at how well it is holding up.
Oh, Paul, BTW, you are the friend in I mentioned in my post above!
I'll need to do the same with my Inglis Royal 100's tub!
