funktionalart
Anyone aware of a direct replacement (I prefer N.O.S./Original for no-surprises fitment) for the unit described and photographed below?
FSP
W#517472
HOWARD IND
Loyd Scruggs Div.
Model 1085-3
115v 60CY
16w 003HP
IMPEDANCE PROTECTED
My fridge is 1963 Coldspot Spacemaker 14,
Freezer Fan is somewhat weak--getting a frequent harsh squeal as well which has me thinking the bearing finally has given after 53 years. I'm not completely sure if this is a big contributor to the frost over I have discovered yesterday.
Fridge has been running 3 months--fridge box is ALWAYS consistent at 37-40 degrees, Freezer tends to hang in the low teens, sometimes down to 8 degrees (ran consistently at about -5 for the first couple months).
I shut the unit down last night to de-ice--one pic shows the frost-over--at least it's uniform/even! I Let it all melt on its own and everything drained nicely down into the pan.
Defrost timer is working, in fact the heater's running on the unit right now and the front mullion between fridge/freezer is warm. Can't yet tell if any heat is getting to the evaporator or not... Door gaskets are all good, no leaks.
A little stumped, but it is only a drinks fridge so no big deal to me if I have to defrost manually every few months.
Thoughts/input appreciated--especially regarding a proper direct swap fan replacement. Thanks, all!
FSP
W#517472
HOWARD IND
Loyd Scruggs Div.
Model 1085-3
115v 60CY
16w 003HP
IMPEDANCE PROTECTED
