1964 Frigidaire Custom Deluxe washer
And now a word from our sponsor.   "Use All, the controlled suds detergent."   "Rinso Blue, Rinso White."
"Tides in, dirt's out."   "Tide, the washday miracle."  "Use new Blue Cheer, for brighter, whiter  washes."
Brake clips .....
The brake clips are made of spring steel .... a higher carbon steel and heat treated. One thing I did on every brake rebuild, I bent used clips closed so that the open ends just touched. Then heated them up with a torch to glowing orange hot and dropped them in 30 wt motor oil to quench. I did this to rejuvenate them and renew the temper if for some reason the steel had weakened over time or use. A lot of these springs I had to renew since plenty of them were found bent because of rusted brakes .... and I didn't have the luxury of obtaining nos clips. To date the renewed clips are still going strong and hold the tub tight during agitation.
Bud - Atlanta
Upper housing lip seal .....
This seal comes glued in place by GM. The old ones are tough to remove and after removal you can see the glue they used. I had a new one to fail. I always glued the new ones in, but the first one popped out while the rebuilt washer was in use. Since that failure, I now take a small blunt punch and peen over the top edge in 5 places evenly spaced apart to hold the lip seal in place and prevent it from ever popping out of the recess. Just a bit of extra prevention and the other 4 I did the way have stayed put. You probably could omit the glue and simply peen the edge and get the same result.
Bud - Atlanta
