1964 Frigidaire Frost Proof - HELP
I don't know the drawer measurement. My Canadian FPIC-12TJ has two drawers and it has a wider 32" cabinet. The US 12TJ have a single hydrator drawer which is much larger but I never had one of those (the US version was not available here in Canada). Maybe they use the same size as some of the later non-frost-proof single door models like the D-116N I used to have.
It's possible your defrost timer has stopped working, causing the evaporator to ice up which then reduces air flow and the ability of the whole system to cool effectively.
It's a fairly easy job to replace. I had to do this on my 1968 Frigidaire frost proof.
It could be the defrost timer or the heater itself. The timer can be manually cycled on for a few minutes to see if the defrost works... If it stopped advancing, you need to cycle it back to the normal mode after about 1/2 an hour so it refrigerates again. If the ice has not melted, it's likely the heater that's the problem.
The defrost heater/cycle seems to be the weak link in these units.  There's at least one extensive thread on the repair process that I recall following here.
