1965 Frigidaire Introduces the Roller-matic Washer
As Dr. Lecter said, " LOVE your suit!"
GM really understood the whole "Jet Age" thing. I think these were the first Frigidaire machines I was aware of, mostly because they did more TV commercials at the time than any other washer manufacturer.
I still remember that marvelous TV commercial where the little boy drags the see-through washbasket with the new Jet-Action agitator inside of it, pours several gallons of milk inside, then squeezes a bottle of chocolate syrup and then turns the thing on to demonstrate the effectiveness of the pulsing. Always thought it was a great idea.
I've looked for this commercial on YouTube many times but nobody has uploaded it as yet.
Differences in Agitators
Was there really an appreciable difference between the Jet Action and the Three ring agitators as far as tangling of clothes? I know using the quadrant method of loading made a difference. There was a claim that apron strings seldom snarl, was that true? There were no such loading instruction the later rollermatics using the JetCone agitator in the 1-18 Models.
One of my favourite models!
The Jet Action agitator doesn't tangle much, the rollover is usually not as fast as with the earlier 3 ring agitators but I just love these Rapidry 1000 machines!
Ken, here's the 1969 commercial you're looking for!
<iframe width="560" height="315" src="" frameborder="0" allowfullscreen></iframe>
This is a video of my WCI-65, just click on it:
I already have a paper copy of the manual but I had to download this one too!
Thanks Robert for making this available![this post was last edited: 11/3/2016-19:19]
Oh, the Deep Action Agitator could tangle,
But, rarely. A full load of slacks and long sleeve shirts might do it.
They just rolled the clothes over much slower than the older Two or Three ring pulsator did.
I still load mine by quadrant out of Frigidaire habit.
John Lefever taught me to back off the water level on a 1-18 for better roll over and he is right.
I can't ever remember an instance of tangling with a 1-18.
Even the solid tub machines usually get better rollover on the "small load" setting. But they still get about 3/4 full on small load or with the infinite control at the lowest setting on the models that have metered fill. And the overflow rinses do raise the level to full at the end of the wash and rinse cycles anyway.
Unlike the solid tubs, 1-18 has the capability to fill at very low levels and when you get it filled to the appropriate level, the rollover is great. The 1-18 also has slightly faster strokes at 360 per minute compared to the solid tub models that had 330 (with the exception of the Pulsa Matic of course!).
It is kind of amazing that GM/Frigidiare ever came up with the idea of a pulsating agitator to begin with. I think probably because it made sense that since a plunger could work that way, so could an agitator. I believe if they had put the dividing quadrants diagram instructions on the early machines, they possibly would have been the leaders of the appliance industry. The early automatic washers were built like tanks and lasted for long periods of time with little servicing. They actually out performed every other automatic washer in every area other than sediment disposal. Westinghouse had them and every other machine beat on that count, but were poor performers at washing and spinning. The Jet Action cone agitators were different in the fact that they actually pulled the clothes down with the agitator and not so much the pulsator at the bottom, which caused more linting than the earlier models. They were still good machines and fairly well built. The transition from solid tub to perforated tub brought more troubles with designing. But by then the big boom of automatic washers was over. Most people had an automatic washer by then, so mostly were replacements or first time buyers. In the beginning, there were certainly a lot of different companies and designs of automatic washers and dryers. By the end of the 70's all automatic washers were either top load agitator machines that moved back and forth or front load machines. Gone were the solid tub machines too. Speed Queen was the last to abandon the solid tub.
Not really Bruce.
Think about washing clothes by hand in a tub. Do you push down, or swirl side to side?
A mechanical engineer who worked for GM back then likely got the idea from their overhead valve V8 engines. A cam shaft lifting the valve stems by way of cam follower lifters which are then spring loaded to return closed.
The Frigidaire transmission wasn't so different. The agitator mounted on a vertical moving shaft, rather than a spinning shaft, spring loaded to the down position, and forced upward by the lever, roller, and cam on the motor end.
Ummm
I think the Unimatic mechanism was actually designed by a Bendix engineer in the late 1930's.
GM bought the rights to the Patent? Seems like I had a conversation with Jon Charles about this years ago.
Idea of pushing up and down upon laundry
Along with creating vacuum action was not new nor unheard of; since the Victorian era if not before there were "possers" (metal, usually copper) devices attached to a stick.
I have a vintage "Rapid Washer" plunger and am here to say the thing works very well for washing and rinsing.
Looking at later incarnations of Frigidaire's "Jet Action" agitators they bear some resemblance and seem to operate upon the same principles as a "rapid washer".
The up and down motions force water though washing while at the same time creating currents that force same down to bottom of tub, up the sides and around top again.
http://https//readymaderesources.com/product/rapid-washer-aka-yukon-plunger-free-shipping/
The 3 ring
Agitators do tangle more, but think about it...if the clothes are tangled up, that means they actually MOVED AROUND to start with!, Nothing in my opinion washes better than a 3 ring agitator or a Philco, a Norge is by far best of the back and forth agitators.
