1965 GE Droptop Oven Thermostat Replacement
starman67
Mar 10, 2024
6
Redondo Beach, CA
Does anyone know or have experience replacing the oven thermostat on a Droptop oven? - see pic below
Can the thermostat be replaced through the push button control panel or does the even need to be pulled out?
Thanks,
James
The old capillary bulb broke off in the oven, only the tube part is left. Can I cut the old tube where it connects to the old thermostat and pull the new bulb through the black jacket which already goes through the oven insulation and into the oven ?
Also the new bulb, WB21X5208 (new old stock from 1999 or 2000) is very stiff, and doesn’t seem like it can get through there, but maybe it is inserted at an angle as it is going in, right?
There is no need to push the front guard out of the way, right?
Thanks,
James
Any ideas on how to clean contacts? - it’s been in storage for +20 years and there appears to a some layer of oxidation on them? - also, I think they are copper but not 100% sure.
GE oven thermostat terminals
It certainly won’t hurt to polish it gently just don’t go sanding or filing them. Then the terminals won’t fit properly and you will have a problem.
It won’t do any good whatsoever either to polish them a little the female terminals when they push on they cut through any corrosion, it becomes a strong metal to metal contact.
John
