1966 RCA washing machine overfill mess
marty
May 30, 2011
188
Central Point, Oregon
Hi,
The washer water level switch has stopped working. It has a new air hose, and when I blow on the hose to the switch, it turns off the water. However, when I try to get it to work on its own, it won't stop filling? Anyone else run into this? It is a 1966 supreme 99. What are my repair options?
Marty
adjust
adjust the screw on the back of the water level switch, try just an eight of a turn out. See if it kicks in, then try another 1/8 turn out. Also, a tiny bit of oil on both places the hose goes, so there's less chance of any air escaping. Seems like next option should be a new water level switch
you mentioned that you replaced the air hose to the water level switch. Did you replace it with the same length of hose that was there before. If there's a difference it's going to affect the water level of the machine and need to be adjusted. Otherwise I'd agree with replacing the switch.
Leak
Thanks for the response guys! Upon further inspection, I found a little chunk of rubber missing from the top of the airdrome .. Right where the airdrome transitions into the hose. I cut the hose off the rest of the way, and inserted a section of old tubing, to spice the two together. Some silicone , and I'm back in buisness.
