oliger
1967 Whirlpool "Icemagic". Over the past few months frost has been building up in the back of the freezer. The freezer was getting too warm so I finally defrosted it manually and took it apart. The entire coil was a block of ice. After I got it apart and melted the ice, I manually turned the defrost timer until it clicked. The heater got hot enough to burn my hand, and the drip gutter warmer got fairly hot too. The path to the pan at the bottom of the fridge is clear. Next I set turned the timer to where the slot was straight up and down, to see if it still moves on its own, and it does.
I am drawing a complete blank here. It seems like it should be defrosting, nothing appears broken. But ice is still building up.
