1969 Malleys Whirlpool Washer
Can anyone suggest where I can buy the rubber balls for the suspension rods of a Whirlpool / Kenmore washer ?
Ideally also the tub cap rubber seal for a 24" machine although I realize that might be close to impossible.
Regards,
Tim
Hi All,
I have made good progress on the washer restoration.
Unable to source a replacement agitator shaft I have repaired the original by machining out the old corroded section, filling with a shaft repair compound and then remachining to the original profile.
Otherwise lots of cleaning, rust treatment, painting and happily some REASSEMBLY have also occurred.
@washerlover - thanks for your note Todd. Glad you like the car !
Regards, Tim
WOWZERS!!
You're making great progress and coming along nicely!
I'm getting excited to see this WHIRLPOOL all back together again and in service! And also getting to see a MUST video of this WHIRLPOOL in action!
Cheering for you on this side of the computer screen!
;o)
Tim, can you tell us more about this "shaft repair compound"?
There are many machines out there of all makes that suffer from shaft corrosion issues... knowing a bit more about these products could help bring more of them back to life!
@hippiedoll
@stricklybojack
Thanks so much - it's a good feeling having it going back together.
@lowefficiency
I used LOCTITE EA3478 which appears to be designed for repairing shafts and the loads they are subjected to. It's a two-part epoxy with metal filler. It was thick and difficult to apply uniformly over the long section of shaft I needed to fill, even with the lathe turning slowly. I erred towards adding too much knowing that I would be able to machine it back down to size. Needless to say the old corrosion needs to be removed completely before building back up with the repair compound.
Hi Thomas,
I did not know that Whirlpools were made under license in Brazil as they were in Australia.
Are there any online parts retailers ? Parts for 24 inch machines seem hard to find in the USA (and in Australia).
Regards, Tim
Yep, Whirlpools were always 24 inches in Brazil, from 1959 to 1989.
In 1990 the Brastemp Mondial (Whirlpool World Washer) replaced the vintage platform.
Until today parts are widely available there as they were extremely popular. A luxury item at the time, but far the favorite washer.
You can find brand new drums, tubs, agitators (super surgilator) "tragic"-mix filters, timers and...TRANSMISSIONS!
I'll try to discover if there's any online parts retailer...
Other alternative is ebay, in Brazil called Mercado Livre. or also OLX
www.mercadolivre.com.br
www.olx.com.br
Search for "Brastemp Luxo" or "transmissão Brastemp Luxo" or "Brastemp antiga"
Parts For WP Belt-Drive Washers
Unfortunately WP-US decided to discontinue almost all parts for these machines in the US around a decade ago, but because this design was by far the most popular washer design in the US [ during their almost 40 years of production ] there are lots of dealers, repair folks that still have parts and are selling them on Ebay etc.
All of the mechanical parts of the 24 " and 29" are the same right down to the agitators.
Major differences are the cabinet, cabinet top, tubs and baseplate. Many electrical parts may be different because of different voltages etc.
John L.
Hi Thomas,
Thanks for the links. I will definitely check them out. I would never have dreamed of looking in Brazil for parts.
Hi John,
I have been able to find most mechanical parts this project has required (seals, bearings, spin tube, suds valve, etc.). The only part that remained elusive was the agitator shaft and hence I went down the path of repairing the original.
It's a testament to Whirlpool's rugged and reliable design that it remained almost unchanged for multiple decades and we have the benefit of plentiful spare parts (for now !).
I would like to try and find a new upper tub seal for a 24" machine as mine is still intact but rather delicate.
All,
This weekend we installed the outer tub and sealed it against water leaks (hopefully). We reinstalled all the internal hoses. We also installed the inlet solenoid valve. The machine did not come with a valve and I was not able to find one that was a drop-in replacement for the mounting configuration of the cabinet. I ended up finding a valve that was a close fit, elongating the cut-out in the cabinet for the hose connections, and making an adapter plate to mount the valve bracket to the cabinet.
Thanks everyone for your interest.
Tim
Hello Everyone,
Making great progress on the washer restoration. After allowing the tub sealer to set we filled it with water to test for leaks. Fortunately no leaks were apparent from the tub, however, two of the hose connections underneath were leaking. I replaced the original spring-type hose clamps with new worm drive hose clamps and that fixed the leaks.
We reinstalled the spin basket and powered the machine to test it for free and correct operation. It was initially not running very true and I found there was still some rust inside the basket center tube causing it not to tighten down square. Removing this rust fixed the problem.
Then we reinstalled the surgilator, tub ring, fill hose, snubber, cabinet top and lid, reconnected the lower wiring harness to the control panel and reinstalled the control panel.
Photos of the continued reassembly below.
We have done some basic tests of the fill level switches, agitate and spin operation which all seem fine. Videos of these below.
