ponchoguy
I've been noticing for a while that if you're sitting there watching the machine work, it seems that it has "stalled" in a cycle (not going into wash for example). Then, you open and close the door and it starts to work.
It's not that it DOESN'T work, but it seems that it's taking longer than it used to do to complete a cycle. It seems that virtually every time if you open and close the door, it will start the cycle, doing nothing else but opening and closing the door. I've tried to push on the door when this happens to see if it's a door switch issue, but it doesn't seem to help. Opening and closing the door most of the time will.
The fill valve was replaced in 1994 with a new WLP part at the time because I left the garage door open on a 2 degree winter day overnight (kitchen is over the garage) and the valve froze. I changed the valve and it's been good since.
Would you change the fill valve in these cases? Ebay sellers among others have good USA made WLP units (not the newer imported ones) at $20 and under with shipping.
Any thoughts are appreciated...
