I have changed the panel on my Calypso washer. The procedure depends on how the control console is engineered. In my case the touch panel is the entire front of the console. You haven't provided the machine's model number in any of the three postings of your question. However, I found what should be the eBay item you referenced and it appears the panel is a separate piece that fits into the front escutcheon of the console with two ribbon cables to be connected. There are four mounting studs on the backside of the panel, I suspect the machine's motor control board mounts there and the ribbon cables connect to it ... so you'll need to remove the motor board from the bad touch panel and mount it to the replacement.
