Early Kenmore, triple dispensers
Not really likely to overflow even at full water level you would have to set it through 10 more dispense Ashens to get the machine to overflow, and since this machine will operate with the lid open, you would see that you’re causing a mess and it wouldn’t be a big flood even if you did it, this would be like standing there and holding the little fingertip water dispenser models where you could wet an item for spot scrubbing, so long that the tub would fill up and overflow I don’t think it’s ever happened.
Reply number 34, hi Dominic, it’s actually very easy to change the transmission and a direct drive washer. It was the easiest modern washer ever to change the transmission in the only other machine that came close were the GE filter flows were quite easy to do it transmission swap
Probably the next easiest machine would be a whirlpool belt drive washer. They weren’t too bad to change. To change the transmission in most other machines were so labor-intensive it was almost never done generally when you had a Westinghouse WCI, Norge and several other machines transmission fail It was the end of the washer 90% of the time nobody wanted to pay for the labor for changing a transmission even Maytag you generally never changed the transmission on thankfully, for Maytag, they didn’t have much trouble in the early years of the machines life.
John
