warmsecondrinse
I'd like to run a situation by you to make sure I haven't missed anything major.....
My mid-60's building ( ~200 apartments and 14 floors) has a 2-pipe heat/cool system. The air handlers (aka 'terminal units') are original. At the latest board meeting (just before the switchover from cooling to heating) a number of people complained that the units were "damp", "smelly", "moldy", etc. A sufficient number of people agreed to authorize the board to 'look into doing something about the situation'.
Every spring the building crew checks units to make sure condensate pipes are clear & functioning. They also change the air filters. The building is responsible if something breaks but owners/renters are responsible for maintenance.
Given the 'demographics' of the people complaining, I'm willing to bet none of them are aware the units even need to be cleaned, much less how to do it.
I'm pretty sure the laws of physics haven't changed lately so there's really nothing to be done, correct. Perhaps give the condensers and casings a thorough cleaning and make sure the drain pans are flat and tilted properly so no excess water pools.... and that's it, right? Dehumidification during the cooling season is a function of the temperature of the chilled water flowing through the unit in comparison with the temp & humidity of the air flowing over it, right.
I have seen some corrosion of the fins around the edges of the condensers, but certainly nothing at a level that would warrant concern if this were a window a/c unit, know what I mean? i have noticed that the units need cleaning every other month during the cooling season, else mold starts growing. But that's normal, right?
Has condenser design/construction really improved so much since the 60's that it'd be economically worthwhile to replace them? I'm leaning toward "no" but I'd like the advice of some of you experts.
The units certainly have enough COOLING power at present, but I have dehumidifiers totalling 130pts/24hrs capacity running 24/7 and I rarely get the humidity below 55% during the summer.
The ONLY thing I can think of is that the condensers have corroded more in the interior so dehumidification efficiency is lost and mold growth is encouraged.
Thanks!
Jim
Thanks!
Jim
