What's frustrating is this subject of rinsing as it concerns modern WP FLers vs the subject washer is from 2006 and totally different. There re cycles whereby the rinses aren't skipped, like towels or whites. That doesn't prevent one from using those cycles for much of your laundry. You are not stuck with using those cycles for what the label says it's for. If a basic cycle meets your expectations, use that for as much laundry as you can, simply adjusting wash water temps and spin speeds. the modern WP/MT FLer discussion needs to b3e with the current generation. But I will say, colors can have an added rinse by adding an extra rinse.
