2nd battery for Toyota-san
washman
Sep 8, 2013
1,972
o
Yesterday the Toyota-san would not start even though the lights came on and chimes went off. Turned key, nothing just a dull click.  Ugh either solenoid or start pooched.
I used the USA made Rizk charger, put on 20 amp charge and it pulled about 8-10 amps. Let it sit that way for a bit, went to start, nada.
Turned it to the 550 AMP boost, turned the ignition and fired right up.  Looked at my receipt, 6 years 4 months of use. Got to work and at lunch, went to Advance and had a new battery installed.  The existing one flunked the discharge test, only recovered to 11.2 volts.  Alt is fine so far as I can tell because the warning light it not on and if the alt was pooched, car would not run at all because of electric fuel pump.  Running voltage was 14.2.
In the end, the new Johnson Controls sourced AutoKraft battery is carrying the freight and Toyota-san starts better now.  Can't complain on the old battery, it gave me 6 years of use.
New one is flat 3 year non prorated warranty.  After that, if the battery pukes, you buy a new one.  Not sure if it is union made or not. :)
"Toyota-San"?
anything like a "Mazda-Buru"?
There actually was a Honda-Zuzu. The first Honda Passport was an Izuzu suv.
The Izuzu Ascender was a GMC Envoy.
a few words of wisdom....
don't always go by the dash idiot lights, a gauge would be better to see exactly what amps the alternator is putting out.....
if alternator is dead, vehicle would still run, all on battery power, until it dies out....
probably the best test for an alternator, start, and remove the positive side battery cable, it vehicle runs, ALT is OK, if it dies out, ALT needs replaced....
the battery is only there to start the engine, and a few accessories if needed when the engine is not running.....that's about its only purpose...
we miss the days of simple troubleshooting for cars......
Sears DieHard used to be one heavy duty battery to have.....buy it once, and never need to again....
You're right on that martin
I absolutely hate idiot lights.  I'm betting the alt is good, I may well be wrong but I have confidence in Denso products.
Toyota-san is my pet name for the car.  #1 quality all the way, very very good.  It drive long time :)
Hi Frig!
My Jeep Grand Cherokee went trough five, yes count them five Sear's Die-easy batteries in five years.
Alternator was putting out 130 amps, gauge was showing 14 volts input.  Battery would not hold a charge.  Put the battery on the tester, it would show a dead cell.
Finally I told them, I was tired of being left sitting, that there could not be that many defective batteries we need to find out what is going on.
End of the day, the alternator was putting out it's rated amperage, but it wasn't reaching the battery, because there was a loose negative battery cable attached to the frame.  Tightened that down, and no more blown batteries, no more cold days in the parking lot.
I still carry the ready start in the back.  It has come in handy this winter helping other stranded motorist, but my Die-easy, is now a Die-Hard.
I'm one of those people that like to buy american if possible and practical, but now that I've owned a Toyota, I'm thinking that's one of the the things the Japanese got very right. I have a 2004 Prius and absolutely love it, most reliable car I've ever owned, and that's with 195,000 miles on it! Not a single repair in the 10 months/ 20,000 miles I've owned it! Oil changes every 5000 miles and gas once a week or so. Only burns about half a quart of oil between changes and still gets 50 mpg in the summer! Mine won't be so cheap if it needs a battery (hopefully not!) Because it's a hybrid and has two batteries- the small "starting" battery which is around the size of a lawnmower battery, and is only used to run the electronics in the car and give it the "OK" to start, and the large, 200+ volt battery for the drive wheels that's under the back seat. That's the expensive one, about $1000 for a rebuilt one or $3000+ for a new one from Toyota. Yikes. I'll most definitely be buying another Prius if I wear this one out, a big *if* because they are known to do 3 or 400,000 miles easily. I've owned American cars and this one has been the best by far.
Tom, i don't know how many voltage regulators I replaced on my old cars but it's de many! Now they make electronic replacement regulators that look the same from outside but they are worse than the original mechanical ones. There are also replacement mechanical voltage regulators that are cheaper and non adjustable. The one in my 1965 Buick Wildcat was never replaced, it's still the original style Delco-Remy. Years ago, I bought a replacement at the GM dealer for another car but it was the exact same as the aftermarket one available at NAPA with the last 3 digits of the GM part number stamped on it and a higher price...
BTW Toyota alternators fail too, I replaced mine twice last year in my Camry (both times, the idiot light came on). They were rebuilt units and the second one was replaced at no charger but I had to remove it... The original one was already gone when I got the car and the Toyota dealership that serviced it didn't bother ordering the original as it's too expensive!
I also replaced the alternator in my Toyota pickup years ago but I have done about 100,000 miles since and it's still OK. This one does have a voltmeter to tell if something is wrong. I had other older cars that were equipped with ammeters that weren't very accurate. Some seemed stuck as their needle wouldn't move in any situation, others were pointing "discharge" when everything was fine...
Hi, Ben!
Aside: What year is your Toyota-san? I retired the Mighty Geo after 24 years and 270,000 miles. As you know a Geo Prizm is a rebadged Corolla. In its place is a shiny black Ford Fusion. It certainly won't last as long, but I don't put as many miles on a car as I used to.
Frig the Toyota-san is 2005, purchased new. It has 94K on the clock. 2 AC condensers, first thanks to a rock, 2nd due to warranty.
Struts, shocks replaced.
I did the plugs at 90K myself.
Exhaust is original. As is starter, water pump, compressor.
Replaced the fogged over headlight assemblies 2 years ago with aftermarket CAPA certiifed made in Taiwan units from Rock Auto.
Let's see, oh the little door in the center stack that covers a storage area broke.
Done 2 sets of brakes on front, rear is still original.
Running non union Cooper Touring tyres, the OEM Junkstones barely lasted me 20K before they were too thin to drive on. I think they are the CS4 Models, not sure, there is a slight pull to the left that went away when I put union made General Altimax Arctic tyres on for the winter. Methinks the Coopers are but for one more summer season.
Other than that, it is about as exciting as a box of corn flakes. But it is paid off, gets me from point A to point B with no drama. That means I had extra quid to buy a US made bench grinder along with a US made battery charger, use good detergent in the SQ and maintain my broadband internet access.
How could you retire the Geo? I thought the goal was to have the Mighty Geo That Lived Forever. LOL
(Seriously, though, I'd have been tempted to at least try to hit 300K...assuming the car wasn't facing expensive problems.)
Probably not... But I wonder if even a modern Toyota could do that nearly 300K miles/24 year trick on the MN prairie... If nothing else, there is so much else that can go wrong on a car now vs. 24 years ago. And I recall reading something 25 years ago (roughly) that indicated that Toyota had been overbuilding their cars, and was allegedly considering ways of building cars that weren't quite made to last forever.
rebadged Corolla
I remember in the early 80s when it was announced that GM and Toyota had formed what I think must be the alliance that resulted in Toyotas sold under the GM names (starting with the Chevrolet Nova of the 80s). About that time, we visited my grandmother. Since it was vacation time, I was able to stay up long enough to see a chunk of The Tonight Show at her house. I recall Carson making a crack about the GM/Toyota deal. He said the car they produced would be called the Toilet. (Merger between names. I think the let in Toilet might have come from Chevette.)
I bet neither Toyota nor GM were terribly amused by Carson's crack. LOL
"Johnny Carson"
I remember that episode too. I think he meant Toyoelt. It sounds like toilet. Toyota/Chevrolet.
The Pontiac Vibe and Toyota version were the last models produced under the N.U.M.M.I. joint venture in Freemont California. Prior to that, it was an all GM plant which produced mainly mid size cars. Today it is the Tesla plant.
I have had the pleasure of riding in a Tesla. I was very impressed.
It is fast! Brother in law is a Chrysler designer. They test all the competition.
A second Tesla facility is being built outside Las Vegas Nevada.
The N.U.M.M.I. plant did produce Chevy Novas, Prizm, Toyota pickups like mine and the Pontiac Vibe but the Toyota version, the Matrix, was produced in another plant in Cambridge Ontario.
There were some RHD Pontiac Vibe made for export to Japan and rebadged as Toyota Vibe at the N.U.M.M.I. plant but these were not sold here in North America.
I had a bad experience with my Toyota Avalon which had dealer service its whole life but the engine lost oil pressure and died at 140k miles but it was a 15 year old car. I have had most GM cars last longer. I have a fairly new VW Passat now fingers crossed.
The Mighty Geo, with 270,000 miles on it, had its original clutch and exhaust system---although truth be told it was getting a bit loud; needed a new muffler. I've never had such a reliable car. Not only was it relatively inexpensive to purchase, it cost very little to repair over its 24 years.
New cars are very high tech! The Prizm didn't even have power windows. The Fusion has advanced traction/stability control, air bags all over the place, hands-free phone and radio controls--it read text messages to me as they came in when I was on the road yesterday---among other things. I have yet to figure out half of it, LOL.
I'm kind of amazed at the Geo going nearly 300K with the original clutch and exhaust system! My father had a late 1980s Honda--and at that time, Hondas were considered by some on a par with Toyota. At 270K, that car had its 3rd clutch, and had had several exhaust systems. Plus lots of smaller repairs.
