3 Speed Hotpoint Washer?
Chetlaham
Mar 11, 2013
4,233
United States
I came across this picture in another thread and I noticed Handwash and Delicate are two distinct selections.
I'm guessing:
Normal= fast/fast
Permanent Press= fast/slow
Wool/Knits= slow/fast
Delicate=slow/slow
Handwash= (?) extra slow (?)/slow
Does this mean this washer had a 3 speed clutch? Or some type of SIS slow agitation? GE never used multi speed motors in their washers, right? How does handwash differ from delicate?
I'm wondering just as much as you. This is one reason I wish tech sheet databases were online free of charge. Whirlpool's used to be publicly available until 2007/2008 on their service matter's site. I know GE customer reps can pull up any tech sheet and associated revisions with just the model number at their computer going back to about 1970. They have them as scanned volume book sets. What I would give to have access to one of their offices with several external hardrives lol.
Hmm
Interesting that it is badged as a “multi-speed washer” though. Makes me wonder if they paired a two-speed clutch with a two speed motor or something like that. Pretty sure the multi-speed clutches were rather brief in their production due to being problematic.[this post was last edited: 2/13/2022-07:23]
Multi Speed probably is marketing speak for combinations of high and low.
There also was a variable speed GE clutch, which has been discussed.  Did the variable speed Hotpoint that came up on a recent Pic of the Day use that clutch?
I agree with Glenn about the marketing. By the time this washer was built there were only one and two speed clutches with single speed motors on these machines. The multi speed clutches and variable speed machines were not made for too many years.
I know whirlpool was using speech like this on direct drive machines. A one speed would state multiple combinations even though it was a single speed. Pulse agitation was considered a speed.
Multi speed Ge Filter Flow washers
GE of course from the mid 50s made one and two speed washing machines, then in the mid 60s they introduced a four speed clutch on the Filter Flow washers.
the Four-speed clutch either allowed you to have four or three agitation speeds depending on the model the machine, even though the three speed models really had four speeds but you couldn’t utilize them.
Around 1968 when electronic technology advanced GE had a variable speed clutch but didn’t really offer any virtue over three or four speeds so that didn’t last long,
several other manufacturers tried infinite speed agitation and it was also a total bust there was no advantage and therefore no great sales.
I don’t think it’s been established that the Hotpoint in question in this thread has intermittent agitation the setting on this machine might just be a silly duplicate setting.
John L
I think temperature and heater power are somewhat similar to agitation speed and frequency/time on a washer.
A to high heating output on a dryer can scorch items - with the same air flow, more power mean higher inlet air temp. That can be problematic for items especially heat sensitive. This dryers might have a heater made up of 2 heaters.
On a washer, that is analogous to the agitation speed.
Even if exposed to to much very briefly, damage can occur.
On the other hand, dryer temp is usually measured at the drum outlet and reflects the overall laundry temp more closely than air inlet temp.
Here, a to high temp can still damage laundry. But usually, that takes longer.
On a washer, to much agitation regardless of speed can wear out clothing.
Like overdrying on a high temp setting.
For example, wool firbres aren't fragile per se. They can put up with a lot of force. But to much agitation can cause felting. There, shorter agitation times are key while action itself can be varied and us usually just kept lower to prevent damage due to the typical made up of the items.
Thus, an intermittent agitation for hand wash items makes sense.
On the dryer side, synthetic items often aren't temp sensitive per se - most stay perfectly intact up to typical Cottons dry temps.
However, a hot inlet air stream could easily be over the temp limit for such.
