This machine blongs to my 82 years old mother. Suddenly it's main motor stopped turning one day. I opened the back and top covers. The water is filled to the middle of the glass front door. Water pump works fine to fill and to empty the machine. The electro-mechanical program switch block (programmschaltwerk in German) works and the spindle of the program switch turns. I also hear some noise coming from the electro-mechanical program switch block that should correspond to the motor left and right turning cycles. But the main motor does not move.
I took the motor out, took it apart. There is no burning smell. This is a brushless type motor. I tested the 6 cables of the motor and compared the resistance values with the manual and they are ok. The capacitor of the motor is also tested fine.
So, from here, where should I check? I need a service manual for a step by step diagnosis, but I do not have it.
Similar machines are:
AEG Lavamat Clara SL
AEG Lavamat Nova SL
AEG Lavamat Nova S
AEG Lavamat Record SL
AEG Lavamat Saphir SL
If somebody has a service manual for one of these machines, I would be very happy to have it. I can understand english, german, portuguese, spanish , so any of these languages would be helpful.
AEG Lavamat Nova SL
AEG Lavamat Nova S
