40's 50's? GE dishwasher/sink in Ohio
Anthony:
The Model is SE120B
The Serial Number begins with '5320' which translates to Build Year of 1953, 20th week, which translates to the week of May 20 (plus or minus).
Disassemble and clean the pump carefully.
If you haven't already, hook up a hose from the water valve to a faucet and test. If plugged, carefully disassemble and carefully clean the valve filter.
The impeller is really in sad shape. And they are next to impossible to fine new. Generally, one needs to find a donor machine to get a replacement impeller.
The S-10 Mechanism Parts Listing (above) is virtually the same as the S-11 Mechanism used on the SE120B models. I don't have the SE120B listing on paper; I only have it on microfiche.
Mike
Thank you,
Mike,
I am in the works of getting a new impeller / geting a mold made to have a new one made. That is grate info to have on hand. I have the pump and water valve cleaned and checked both are working now :)
The tub had a 1/4in of lime and calcium on it and the CAL rod had a 1/2on of it!!! Lots of cleaning. But I got it! Now who can help me find a discharge pump seal and discharge pump impeller?
Thank you
I don't know why I dident do that when I had it apart oh well you know what they say you can't fix stupid!
But it's leak free now :) thank you.
