Fancy That:
The tub and agitator on the machine look identical to that of a SQ machine of recent...
Looks like a pretty darn nice machine, in my opinion, although, as with my TL machines (and FL's for that matter), full loads won't get the best possible rinsing/washing. I like the control panel design and all the knobs and options to choose from. This one is a gem PLEASE use it with Warm/Hot water when possible, to save scum buildup and mould in the machine!
Based on whats said above, a pause during the (Normal?) cycle may be a "hidden" cool-down period, for washing mixed fabrics, to prevent setting creases, or a soak for the rinse to all full fabric softener penetration? I don't really know - so perhaps I shouldn't be talking!
But the slow fill speed (esp. on Hot) will be to save (hot) water and energy. Or, if its the opposite, the machine might use more hot water than cold water to negate cold pipes or something... Only Cold and only hot fills will be slow - esp. the hot ones with a "saver" valve fitted. A mixed fill should take less time, provided the water pressure in your home is good and the filter screens in the valves or the tap aren't clogged up.
The manufacturer may have cheapened out and given this thing fill valves for an FL machine of the era (Amana and KM are related, right?), just used two low-flow valves to save time/money on design (Our old "Electrolux/Simpson" machine had this... 10+ auto fills) - at the expensive of cycle/filling time. Same goes for the timer - which may just "repeat" the Permanent Press cycle for Regular wash, to save money on timer design. Don't quote on that, because I don't know anything!
