Glad you guys like the video! The machine has eight lights in all. Tub light, and ozone light, front pushbutton light, one light in the water level control, one light in the temp control, two lights in the timer area, and the top light that is covered with the purple gel.
The water level is slightly higher because I replace the water level control with a 14lb capacity control in all my early KM/WP machines. That way the tub can be filled higher. It is more gentle on the clothes, and increases capacity that way. The 14lb tub is no larger in size than the tub in the early models anyway, so it makes no difference. I consider it an "update" <:
