My cousin has a 1961 Sears Coldspot fridge in aqua blue that has been running continuously since it was first installed. The other day he said he found the lights out in several rooms and the fridge not running. Older home with fuses and apparently wiring that spans several rooms when it should not. Any thoughts on what could cause the fridge to start blowing fuses all of a sudden?
My first thought would be one of the heaters perhaps burned out and is shorting against the cabinet. One other option is that he put the wrong size/type of fuse in the box. I suggested a slow blow type fuse to handle the load of the compressor starting up.
