I learned how to do laundry with this particular model.
As I've mentioned in the past, my parents had this model in alvacado, but not the matching dryer. It was an easy machine to learn, just properly load your clothes, add bleach,fabric softner if desired, select the proper letter for your speed, and water temp, and push the timer in, and there you are. The cycles were the following.
A. Cottons Linens White.
B. Cottons Linens Colored.
C. Permanent Press White.
D. Permanent Press Colored.
E. Delecate Fabrics.
F. Washable Woolens.
G. Pre Wash Or Rinse.
H. Spin only.
Yes the agitation would change to slow during A, and B, cycles when the bleach would be added in, then change back to normal for the last 2 minutes of the wash time. On C, and D, it would change to slow agitation during the cool down, it would even drain on slow, then would agitate while filling up with cold water about 2 or 3 times before the final drain which would be normal.
The Kenmore direct drive I bought in 2000 changes agitation speed during the normal cycle. They sure don't make them like they used to, that old alphabet machine ran until 1993.
When you have time, would you please make a video of the machine going through either A,or B cycle ? Thank You, and have a nice day.
