They're Out! Miele W1 Washer and T1 Dryer
They look kind of like Asko's new washers too.
              Asko                             Miele
If my current Miele W1986 washer stops working I will get the top of the line model, but not the dryer. I don't mind having a dryer of another brand, plus I use natural gas to dry my clothes so an electric or heat pump dryer is not attractive to me.
Have nil interest in T1 dryer
But should a W1 washer pop up at some point in future (used), and at an attractive price, that would be another matter. Especially if by then Big Bertha (Miele W1070) has packed it in.
Will be interesting to see how well these Miele heat pump dryers sell in USA. This and hearing real world reviews from actual owners. Fact that ABT seems to only have the W1 washers in stock while dryers are "special order" (IIRC) is telling. Perhaps they don't want to be saddled with inventory that cannot be moved.
Am not entirely sure, but IIRC these heat pump dryers have a definite lifespan. Maybe something to do with the refrigerant system? In any event once whatever triggers the dryer to be then be no longer useable it must be discarded. Suppose this is like air conditioners, refrigerators and other similar appliances that use condenser systems with chemical refrigerant.
OTOH vented and some vented dryers can (and have) lasted decades, and then can be repaired (assuming parts are still found) to go several more.
Definite lifespan
Anything has a finite lifespan, period.
Heatpump dryers have 2 major limitations to their lifespan:
1. If anything about the refrigiration system goes wrong, repairing is costineffective. That however is verry rare.
2. By design, you can't remove the condenser to clean it. Thus these have a quite elaborate filtration. If you don't take proper care, the condenser will clogg and the dryer will slow down to the point of unusability.
Mieles system is pretty good both in terms of ease of maintanance and longlivety.
Have to say, I'm not a fan! They look like all the other plastic crap out there, even though they'll be better-built than most. Are the classic-styled Little Giant machines still in production? Stick with those while you can!
