8 Reasons Using Liquid Detergent Is Better
I don't think I'd go THAT FAR....To me, it doesn't look watered down.. and the clothes come out clean with a slight scent. It's not like you're washing clothes with just plain water. I think I may try Gain when I run out because I know it has enzymes.. and I always liked gain. I noticed on amazon they still make powdered gain..
I also noticed on the samsclub website I saw ERA detergent... remember that? I forgot all about ERA... that was like a liquid detergent before liquid was even a common thing.. Only the price was CHEAP... I'm guessing it's not the same ERA
Era detergent is another example of a mediocre brand that is basically Watered down performance detergent.
If your clothing isn’t that dirty, I’m sure it works well enough, but we see machines every week that are the victim of cheap detergent and two little detergent, etc. etc.
All of the companies (Henkel, P&G, Unilever, Kao, etc etc etc) make detergents with differing components; on the highest level to make sense for the local conditions/market but also in the cheaper lines to reach their price point and expecation point regarding fragrance, viscosity, etc etc.
A good rule of thumb is that Tide/Persil/Omo/Miele/etc generally gets the all-singing, all-dancing (sic) multi-enzyme (5-6) cocktail together with the truly optimized formula for local conditions.
(In North America) the next-tier are the Gain/Cheer/Purex Advanced/All/A&H Power/Seventh Generation with 3-ish enzymes and a slightly diluted/de-optimized local conditions formula
The next tier are 0-1 enzymes like Simply Tide/Era/A&H basic/Purex standard/house brands.
I'm being a little figurative here, but the point stands----there's an enzyme cocktail for every purse and purpose (thanks General Motors ;) )
Calibrate your detergent to meet your needs and you'll probably do best...every load isn't always needing Tide Ultra Super Mega Max...but washing twice in cheap Purex is no savings either.
I think anyone who knows how to do laundry properly... even working with filthy clothes can keep their machine perfectly clean... even if they use cheaper detergents..I mean, I could be wrong... but I don't think I'd blame cheap detergents over the actual user... as almost everyone here knows how many people out there have no clue what they're doing when it comes to laundry
Have often spoke of laundry "Sinners circle" and four basic principles of washing (time, temperature (water), mechanical action and chemicals.
Whenever one of above parameters is changed the others must also to compensate. That is if wash water temperature is decreased chemical, mechanical and wash time each or all must move as well. Opposite is also true; that is if mechanical action is increased other parameters can decrease.
https://jtmservice.co.uk/blog/sinners-circle-for-a-hygienic-wash-cycle/
Mechanical action compromises a bulk of what gets wash clean. If one did nothing but beat wet things against a rock they would come clean to some extent. Addition of soap, detergent and or other chemicals simply brings more benefits to party.
Given enough mechanical action, proper water temperature and so forth even a "poor" detergent by some people's standards can (and often will) deliver acceptable results.
Reply number 34
Very, very true laundress, however, since all of us have the machine we're going to use the only thing we really have choice about is cycle selection, water, temperature, and the most important thing for most of us is the detergent brand and the amount.
It's certainly true that these watered down Products can do an acceptable job if you using enough of them and if you compensate in other ways for their lackluster performance.
One of the reasons I know these cheap national brands are lackluster as I have used all of them. People often give me bottles of this stuff because they don't like it when I'm on service call and I'm too cheap just to throw it away. I'm going to use it often just to wash rags with at the shop where I don't really care about perfect results.
John
OK so I'm clear. Tide actually optimizes their formulas differently for local conditions? So if someone in Cali buys Tide and moves to DC...and take their Cali Tide with them, it's not the same tide had they bought Tide in DC?
If that's true... I had no clue
Not for nothing...
People rag on A&H, Kirkland and other (what they consider BOL) laundry detergents, yet rave about niche high end products such as Molly's Suds, Nellie's and so forth. This as such products are no different really than Kirkland or A&M, least far as powders are concerned.
Molly's Suds powder is nothing more than mostly all salts. Washing soda, sodium bicarbonate, etc... Yet people rave about how "clean" it makes their laundry.
https://mollyssuds.com/products/original-laundry-detergent-powder
As have said obtaining clean wash can be done largely by mechanical action alone. Add bit of chemicals and there you are.
I'm done....
Cleaning clothing in water alone
Hi laundress you're certainly correct. You can get many things clean in water alone when you live in an area such as you do where the water is extremely soft most people don't have that advantage and you need to use good detergent to suspend and carry away the soils that are beat out of a clothing.
I always thought it was too bad that consumer reports is located in a soft water area so their detergent testing temperature recommendations and appliance testing of both dishwashers and washing Machines is a little suspect. It doesn't really take into real world situations for most of the country.
John
It's funny... Kirkland and Sams Club members mark liquids (at least from reading the sams club members mark ingredients list) has 3 enzymes.. I can't find the ingredients list for the kirkland liquid but I'm guessing it's the same... and yet these are the absolute cheapest detergents price wise when you consider how much you're getting.. and yet THEY have enzymes while the other cheap ones like regular Purex, Arm & Hammer, etc don't...I wonder why?
In common with Sears, Miele and other private label laundry products Costco's Kirkland products are made by someone else.
If said manufacturer is already producing product for themselves or others it's not a huge deal to add another name onto list.
Thus key to Kirkland laundry products is to find who (or is it whom?).
Church & Dwight (A&H) doesn't produce laundry detergents with enzymes. They've obviously crunched numbers and realized R&D along with other costs in developing such products likely won't be recouped in sales.
Thus key to finding out much about backstory on Kirkland's laundry products is learning who they get them from.
The HE Butt Grocery Company (giggle) ostensibly creates it's top-shelf private label with Texas washing and water conditions in mind.
https://www.heb.com/product-detail/...-detergent-value-pack-96-loads-150-oz/1695637
Costco, Sams, Walmart, etc specify whatever they think will satisfy their customers at an appropriate price point for whatever product. If that's 3, 4, 6, ... enzymes they'll definitely look for the documentation so they can ballyhoo and promote it.
It was said several years ago that Costco/Kirkland top shelf liquid is Persil (which tracks), as Huish/Sun (which Henkel bought years ago) did lots of private labeling.
P&G is very reluctant to jeopardize Tide with producing much private label detergent (although their bar soaps like Ivory was until recently actually produced by a private labeler that bought the plant in Ivorydale, OH from P&G).
https://www.personalcareinsights.co...tly-in-march-after-first-opening-in-1886.html
That is so cool to me that they actually take local water conditions into consideration for their formulations... especially a store brand... that's crazy... I had no clue that was even a thing. I wonder if they do the same thing with dishwasher detergents?
I will say this.. Normally I get the big jug of DAWN at costco... but last time we got the big blue bottle (same exact designed bottle) of dish liquid.. only it was kirkland... and I'd swear I'm using Dawn... but it does smell slightly differently. It definitely doesn't feel like you're using that bargain cheap dish liquid...
I do remember reading a particular review of the Kirkland liquid detergent in the red bottle.. the lady in the review said she works on a farm or something and that's the only thing that comes close to Tide... so maybe it's like Persil (light) or something? I don't know.
I do know if I ever bought one of those Gynormous bottles of detergent, I would keep the bottle I have now and just fill/refill when it gets low and figure out the measurements because I don't like the way those big bottles dispense... Of course it wouldn't matter if your machine had auto dispense
I think just the number of enzymes alone does not tell much about the quality of a detergent.
Enzymes are among the most expensive detergent ingredients and while they don`t get used up in the washing process (they can do their magic over and over again) a higher concentration of enzymes still gives better and quicker results.
In the thread about European testing standards we just learned that the "Reference Detergent" to which the others are compared to has to provide 0.5 % Protease enzyme.
Some European high end detergents like Henkel`s liquid Persil obviously exceed this amount because they have this mandatory warning on the bottle: "Product contains Subtilisin (Protease), may cause an allergic reaction",whereas somewhat lower performing competitors like Ariel liquid are not required to have it.
It`s obvius that bargain brands like Arm & Hammer or Purex or brands that focus on sensitive skin like All keep their formulars way below 0.5 % Protease.
But the majority of products from those bargain brands are no enzyme products anyway.
Instead of enzymes those products rely on the brute force of high pH levels which may even be a better choice on some specific stains than enzymes in insufficient amounts.
Or one could go with a good enzyme based store brand instead and still save money.
Reply number 39
Hi Mark, it's no wonder the national brands like pure X arm and hammer, etc. don't have enzymes it's because it's a cheap product and they're paying for national advertising and distribution.
The price you pay for most products does not have anything to do with the quality in many cases, private label brands are almost always a better buy, and they're often a better product when you compare brand-name grocery items to the good store brands the store brands are often better and cost considerably less.
Costco is an excellent example of this.
I recently just read that Costco's liquid detergent is actually made by Purcell, this does not mean that it's exactly the same formula and Costco detergent might actually be better it certainly is a better buy.
I've said before that you can go through my whole kitchen and my whole house and you will probably not find more than two or three brand-name items. It's very rare that I end up with anything with a expensive brand name on it in the grocery area, you don't get to be a millionaire before you are 40 by wasting your money on Overpriced products.
My partner and I eat very well very healthy meals. We cook everything from breakfast to dinner from scratch using top-flight ingredients.
We never waste money on paper towels, paper napkins don't even buy vacuum cleaner bags, plastic bags for trash, never had anything like a swiffer there's just no need to buy things just to put in the trash and yet the house is clean enough to eat off any floor Our clothing is extremely clean and lasts a long time if you clean clothing thoroughly at lasts much longer.
John
"Instead of enzymes those products rely on the brute force of high pH levels which may even be a better choice on some specific stains than enzymes in insufficient amounts."
Enzymes also come into play by length of wash cycle.
For best performance enzymes need certain minimal contact time. This is generally around twenty minutes or so. Obviously given proper conditions enzymes will go to work soon as wash cycle begins, but optimal or even good results may suffer with short cycles.
Unilever and others came up with laundry detergents that will work in "quick cycle" (about 15 minutes) such as Persil's Wonder Wash.
https://wiop.unilever.co.uk/brands/...aundry-detergent-24933-64312342-300006467693/
https://wiop.unilever.co.uk/brands/...aundry-detergent-24932-64312340-300006627911/
With short wash cycles chemicals play a more prominent role in wash day.
Commercial/industrial laundries have average wash cycle of 8-12 minutes. Hence you still find same powerful chemicals of old still about; washing soda, sodium hydroxide, sodium metasilicate, etc.... If loads are very fouled two or three wash cycles may be needed, though all would be short in time.
There has been some movement to get industrial/commercial laundries onboard with enzyme products, but again this would mean often lengthening wash times which in turn extends entire cycle and affects through put.
Chemicals can (and have done) nearly same work as enzymes on wash day. However former will often require higher temperatures and over time may lessen fabric life.
Hospital laundries for ages got blood out of textiles using nothing more than soap, sodium metasilicate, and sodium perborate. This was done using one or more wash cycles at temps at or > 140 or even 160 F. What soap and pH didn't remove was bleached out by perborate.
the cycles I use most on my duet... heavy duty/whitest whites... the wash cycle is EXACTLY 20 min's on both of them... I wonder if the wash cycle length on those is based on enzyme detergents...I would guess so.
I think I've narrowed it down to Gain with Oxi Liquid (has 4 enzymes)
Or Kirkland Liquid in the red bottle as the next detergents I'm going to try.
then after that.. I might try Persil
These are my main go to detergents
I usually use a half a scoop of the tide powder and a half a dose of the Aldi's liquid for really dirty, large loads, I almost always mix different detergent, in addition I use a half cup of baking soda in the calypso with a cup of bleach to wash the really dirty stuff.
I was told by our resident laundry detergent expert here on the site that this Aldi's formula contains six or seven different enzymes, it's made in Canada. They claim it's comparable to tide.
The Aldi's detergent is under seven dollars, I usually pick up the tide at Costco when it goes on sale for about $30 a box.
We have an Aldi here.. I think I've only been there a couple of times and I've never even thought about buying detergent there. I wonder how they can make it like Tide so cheaply? I understand it's a store brand and they don't have to advertise.. but still.
Not a big sample size but just a few thoughts... I dunno
So this detergent is sold in America but not made in America? I think I'm at least going to try it. I might be surprised. There's 2 different Aldi's close to me... but I never shop there.
Aldi's liquid detergent
That we get here is made in Canada.
Hi Mark, I can't believe you haven't tried shopping at Aldi I can go to the local Aldi's buy about 70 items and be home in a half an hour. It's so easy to get through their storage because they're smaller And you can find what you want. You're also saving about 50% compared to the large chains. that's a huge savings.
I especially love the fact that you have to put a quarter in to use the shopping cart. It makes a very nice interaction with other shoppers as I often give the cart to somebody else or someone gives me one it also eliminates shopping carts all over the parking lot becausepeople put them away where they belong. If you don't wanna put it away there's usually somebody around that will come and put it away just to get the free quarter, it's a wonderful system that saves a lot of accidents and automobile damage every year.
John
