Hello everybody, how are you guys today? I had a chat with the lg reps today about my concerns for the dryer temperature rating for each cycle. According to Rodney, extra low is 113 degrees, low is at 131 egrees, medium is 143 degrees, mid-high is 151 degrees, and high is 158 degrees. This is all in Fahrenheit and are more than likely estimates. I assume the normal cycle is around 143 degrees based on the tmp settings and is designed for sturdy fabrics like work clothes, corduroys, etc. I believe the lg has higher airflow to compensate for the lower temps.
According to GE, the normal cycle is around 135 degrees on high. Funny how the lg rates the normal cycle at a higher temp than GE and everybody else like whirlpool/maytag. Anybody notice this? At first, I thought medium heat for a normal cycle was too low when I used my mom's lg that matches her washer of the same brand. I was used to seeing the normal cycle on high heat. It's funny how lg's normal cycle temperature is much higher than GE's normal cycle on high heat. That may be a good thing. For example, If I had jeans that say dry on low heat, the least I would use is normal on lg. As a sidenote, I'd use the normal cycle to wash in cold or warm to preserve on color and integrity of fabric.
