cfz2882
got this about a month ago,just getting around to checking it out-at first motor was slow and weak,but turned out a chip of bakelite got broken off pedal and wedged in it-preventing full pedal application,plenty of power and speed once chip removed
Made in USA and showing~spring 1983 date codes,more like a '70s British or European singer internally instead of one of the older(mid-60s-earlier?) slants with the vertical worm drive motor and beautifull steel gears that look like they would last 50 years of commercial service
Luckily,machine came with manual and spare bobbins-uses special bobbins,larger than the usual type.Will see if I can get the hang of operating this machine-probably on of the last US made singers?
