What are the actual wash and prewash times in minutes?
I apologize if this is in the Speed Queen chart, and I have just missed it. I am used to looking at the one for the actual Maytag Commercial (sold and used for commercial use), which is a little more detailed. Note this chart is pretty close to what the residential model, Maytag mvwp575gw, also has. However, the agitation time for the Powerwash cycle is 12 minutes and not 17 as reported on the chart. Also, Normal "Eco" agitation time is about 7 minutes instead of 9 as reported by this chart.
Wash Cycle Questions:
After the washer fills, what is the actual time the TC5 "washes" the clothes. It looks like choosing Heavy Duty will add more time to that. If so, do you know how many additional minutes?
In the attached chart, Maytag refers to this as the "agitation".
Prewash Questions:
Prewash is almost 30 minutes. What is the actual time clothes in the TC5 are soaking? And does the prewash water drain and refill for the wash cycle?
The actual amount of time Maytag soaks the clothes during the prewash cycle is 10 minutes. It does not drain the water. I like this! You can do a longer manual presoak by selecting pause. Do not open the lid. If the lid lock is activated, the water will drain out after 10 minutes.
Thanks,
