gyrafoam
I have a next to top of the line '59 Kenmore Roto-Swirl, and I have been trying to get the inner wash basket out. The first real problem was the (spanner) lock nut. That I had to drill and pull off in pieces. I have a new replacement for it. Now according to the book and everyone I talk to, the inner tub should just lift out. It does not! I am able to push down on the tub and it will travel down an eighth of an inch or so but always returns to the same position. I have used a rubber mallet around the spin shaft to try to knock the thing loose. Somehow it just seems like something is still left to be undone and I cannot figure out what, unless the basket drive block must come out. If so how do you get enough leverage to get it out. It is sunk below the flare of the spin tube and fits down on two tabs from the top. One side is gapped open, but I am not sure what the purpose of that is.I have referred to Robert's '57 Restoration pictures and so far everything looks like it should work. Any ideas will be greatly appreciated!!! -Steve
