mobilemaid
I recently had to replace my mini LG front load washer. I have very limited space for a stack unit in my 1970's home, and only a 24-inch unit will fit the space.
I bought the LG WM1455HWA from Home Depot and had it delivered a couple weeks ago.
The issue I have is that the front door is tinted a very dark color. When the machine is running, you cannot see inside the washer because of the tinted outer glass.
I took the door off the machine to see if I could remove the tinted outer glass and it is a "glued" unit that cannot be separated.
Any suggestions how to remove the outer tinted glass or replace the door so I can watch my close wash?
