A Convoluted Tale of 210 ° arc-cuate washing
jetcone
May 2, 2001
7,688
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
Ever since Robert hit me over the head with BEAM transmissions I've been trying to find the patents that covered that design. I've been looking for years and found nothing, then yesterday BOOM ! In desperation I typed in "fluid drive washing machine" in "guglepatents". I had been typing Beam Manufacturing,  fluid clutch, liquid clutch, doodlebug scooter, all came up DEAD 0 !
To my huge surprise the patent that did come up for "fluid drive washing machine" was from GE, - NOT BEAM !! And it was the complete mechanism that Beam used. So this brought a slurry of questions to mind.
I knew from what Robert had told me that the early Hotpoint were "Beam" machines. And we always knew Hotpoint washers were not made on the same assembly line as the GE Filter Flo's until late in the 60's.
So Hotpoint had to be made somewhere else.
So I kept digging linking one patent to another and finally got down to what appears as the bottom, the first patent for the Hotpoint, Speed Queen, Easy, One Minute design washer.
Its a convoluted tale and it will take some more digging to get the actual answers but from what I learned from the Frigidaire patents history this one seems to parallel that one.
It starts with a man named A.J. Patch in 1931 who invented the 210° arc-cuate drive for wringer washers in Ripon Wisconsin. He also invented the engagement clutch used to engage the agitate shaft. This whole mechanism will form the base of the "Beam" machine. Interesting he lived in Ripon WI where Speed Queen would be found.
I have some early wringer parts books that show his transmission in Speed Queen wringers, so there is a connection I'm sure. His claim is very interesting and I think leads to the Speed Queen moniker, he claims that 180° washing won't effectively turn the clothes over so the machine has to operate for an extended amount of time, so that his transmission which really turns through 220° will turn the clothes over much faster saving washing time at the wringer for the Madame. Hence the commercial name "Speed Queen".
His patent is 1,964,440 Oct 27, 1931 you can view it at "gugglepatents".
Next a patent citing Patch's work shows up in Aug 14, 1946 by a G.P. Castner who works for a company called Solar in Milwaukee WI. His design incorporates the transmission into a semi automatic with a "bowl shaped tub" but adds the snubber plate design, the 1 point suspension, an early version of the fluid drive, the yoke support for the whole mechanism and the centering springs and an early version of "jet-circle" filling of the tub. Interestingly - which I never knew - he points out the advantage that the fluid clutch will actually slip and slow down the tub on unbalanced loads.
His patent is 2,513,844  8/14/1946.
After this is where GE/Hotpoint comes into the picture, all these patents are then cited by GE, which is common in patent law BUT GE also included the entire design elements in their patents - something you couldn't do unless you owned them. So somehow between 1946 and 1949 GE bought these two patents for the Hotpoint machine, or maybe Hotpoint was bought out by GE I'm not sure here, maybe YOU know that step?
Maybe to get into the automatic game Hotpoint had Beam make the machine instead of building a factory and when GE bought Hotpoint it acquired all these patents and as long as Beam could make money building machines GE let it roll? But that doesn't answer how Speed Queen got involved.
However after this point we see the remainder of the patents covering the Beam design coming out of GE.
The next patent by W.P. McCarty of GE was for a "Beam" design automatic that  followed ABC's current automatic in that this machine also had TWO motors, one for spin , one for wash. In fact it cites the Altorfer patent! It also cites the Kirby patent - designer of the jiggamatic Apex, and Kendall Clark the designer of both the Bendix and Unimatic transmissions !!
This patent is 2,646,673 W.P. McCarty 10/19/1949
The next patent from J.C. Sharp at GE covers the cabinet design elements of the Hotpoint which were also used on the Easy and Speed Queen automatics. Also this patent includes the famous GE outer tub lip seal design for the outer overflow tub and the then novel idea of incorporating the entire mechanism onto the base plate so that it was completely independent of the cabinet structure. It is also where the invention of the sediment tube removal system is invented, so central to Beam built machines.
See 2,687,633 J.C.Sharp 10/14/1950.
The first patent I found, which was it appears the last for this design  was from K.M. Hamell for an improved fluid clutch design that shows the entire Beam mechanism in a Hotpoint machine.
His improvement was the addition of small vanes that helped start up the fluid drive from a stop position and this patent is good to give us the optimal level at which this fluid drive should be filled for optimal pickup and de-clutching in unbalanced spin situations. This patent cites the McCarty patent above.
See 2,723,737 11/21/1950 - the day after my parents got married!
So the BEAM design is really a conglomeration of many inventors across several companies. My guess is the early patents were licensed to Hotpoint and Speed Queen and when GE bought Hotpoint it aquired these but I still don't see how Beam got involved unless they were a Toll Manufacturer for GE and as such were able to sell this design to other makers who didn't have the capital too tool up their own factories. GE has always been about the $$$ not the fame.
This may all parallel what Gansky and I found regarding waterless cookware - we've found 100's of names but they were all mostly made by West Bend for direct marketing companies .
AW what do YOU make of all this and what do you think happened?
[this post was last edited: 8/7/2014-08:01]
http://https//www.google.com/patent...a=X&ei=Wm7jU5XyKs2YyATovYHgBw&ved=0CB4Q6AEwAA
The Maytag wringer transmission (both pre and post model E) is quite different from the AMP/Helical drive transmissions.
These are some very interesting findings, Jon!  I can't wait to read through them.
Ben
Excellent research!
now if we can only find out where the 30 degree of stroke goes from the actual transmission to the agitator, all will be good.
Great information. It really shows over time nothing has changed with respect to different companies making strange bedfellows. Same thing goes on today.
Wow!
Great Research Jon! And thanks for sharing.
You are truly the Dr. here.
Amazing finds. Did you find this all out online? Or did you have to also do some book work?
B
Nothing new here...
Jetcone, The link is to "Barlow &  Seeling".  I noticed the " Speed Queen" is listed as "New".  Just guessing but  the wives or a relative might be the connection.  All of the companies  were operating during the great depression?    This "website"  page came up thru barlowgenealogy.com...   Castner's patents mention, Solar Corporation of Milwaukee Wisconsin, a Delaware Corporation?   Thank You!  I had no idea how complicated all of this is.
ALR
[this post was last edited: 8/8/2014-03:59]
http://www.barlowgenealogy.com/Wisconsin/BarSelg.html
Thats an interesting link there
ALR- I forgot Barlow & Seelig were the original Speed Queens. We have a famous business library here in Boston that will have all the company records of acquisitions I must get down there. Kirstein  Business Library! Now I've got search material !!
The Delaware Incorporation means zilch , it was the go to state at the time for all large companies to incorporate in because it was the cheapest at the time. Most at that time were incorporated there but had nothing to do with Delaware.
[this post was last edited: 8/8/2014-09:11]
Barlow & Seelig
Barlow & Seelig Manufacturing Co. <br style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 13px; font-weight: normal; background-color: #fffdec;" />Ripon, WI, U.S.A. <br style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 13px; font-weight: normal; background-color: #fffdec;" />Manufacturer Class: Steam and Gas Engines
<span style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 13px; font-weight: normal;">This manufacturer of laundry machinery was founded in 1911 by Joe Barlow and John Seelig. They changed their name to Speed Queen Corp. in 1949. In their earlier years they made their own motors, which may be repurposed to run small woodworking machines. So far as we know, they never sold their motors as anything other than part of a washing machine or dryer.</span>
<ul style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 13px; font-weight: normal;">
<li>A 1949 issue of <cite>Farm Implement News</cite> has this snippet:
<blockquote>Change Name—The Barlow & Seelig Mfg. Co., Ripon. Wis., making the Speed Queen line washers, ironers and related equipment for ... to correlate its corporate name with this trade name and hereafter will be known as the Speed Queen Corp. ...</blockquote>
</li>
<li>[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px]The company was founded in 1908 by Joe Barlow and John Seelig as Barlow & Seelig Manufacturing. They got their start by taking existing machine designs and improving them. In 1922, Speed Queen was the first company to introduce washers with nickel-copper tubs. The brand name "Speed Queen" was created in 1928. During [/COLOR]World War II[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px], it switched production to support the war effort, manufacturing 20 mm [/COLOR]shells[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px], and parts for airplanes, tanks and guns. Later, it was sold to [/COLOR]McGraw-Edison[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px]Company (which also owned Eskimo fans and [/COLOR]Toastmaster[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px]), and then to [/COLOR]Raytheon[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px]. In 1998, [/COLOR]Raytheon[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px] Commercial Laundry, owners of the Speed Queen brand, was sold to [/COLOR]Alliance Laundry Systems[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-style: normal; line-height: 22px].[/COLOR]<sup id="cite_ref-2" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-style: normal; color: #252525; font-family: sans-serif;">[2]</sup></li>
<li><sup class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-style: normal; color: #252525; font-family: sans-serif;">[COLOR=#444444; font-family: 'Helvetica Neue', Helvetica, Arial, sans-serif; font-size: 14px; line-height: 20px]Raytheon Co. has completed the sale of its commercial laundry business in Ripon to Alliance Laundry Systems for $358 million. Lexington, Mass.-based Raytheon said the transaction closed following the sale of about $75 million of receivables through 1997. Alliance Laundry Systems, which is based in Ripon, was organized by Bain Capital Inc., a private investment firm with $2 billion of capital under management, and Raytheon commercial laundry management. The company's products are sold under the brand names Speed Queen, UniMac and Huebsch.  May 5, 1998 [/COLOR]</sup></li>
</ul>
McGraw-Edison
<strong style="color: #252525; font-family: sans-serif; font-size: 14px; line-height: 22px;">McGraw-Edison</strong>[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] was an American manufacturer of electrical equipment. It was created in 1957 through a merger of[/COLOR]McGraw Electric Company[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] and [/COLOR]Thomas A. Edison Industries[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px], and was in turn acquired by [/COLOR]Cooper Industries[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] in 1985.[/COLOR]
[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px]McGraw Electric was founded by [/COLOR]Max McGraw[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] in 1900 as an electrical contractor, in the business of installing electricity in houses. The founder was aged 17 at the time. The company quickly expanded into industrial and commercial buildings.[/COLOR]<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">[1]</sup>[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] It made several acquisitions over the years, evolving into a manufacturer of electrical products. In 1952 McGraw Electric and the Pennsylvania Transformer Company merged, keeping the name of McGraw Electric.[/COLOR]<sup id="cite_ref-FOOTNOTEOur_History:_Cooper_Industries_2-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">[2]</sup>[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] Thomas A. Edison, Inc. was formed in 1910 as a reorganization of the Edison Manufacturing Co., which had its roots in the 19th century. It manufactured phonographs, and later moved into radios.[/COLOR]<sup id="cite_ref-FOOTNOTEThomas_A._Edison_hand_signed_..._1936_3-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">[3]</sup>[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] [/COLOR]Charles Edison[COLOR=#252525; font-family: sans-serif; font-size: 14px; font-weight: normal; line-height: 22px] became president of the company in 1927, and ran it until it was sold in 1957, when it merged with the McGraw Electric Company.[/COLOR]<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-1" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">[1</sup>
<sup class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">So McGraw-Edison probably bought Speed Queen around 1957 as my machine is badged McGraw-Edison.</sup>
<sup class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate; font-weight: normal; color: #252525; font-family: sans-serif;">This still doesn't explain the GE Beam Speed Queen connection.</sup>
More McGraw-Edison
McGraw-Edison Co. was created in 1957 when McGraw Electric Company acquired Thomas A. Edison Industries.<sup id="cite_ref-FOOTNOTEOur_History:_Cooper_Industries_2-1" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[2]</sup> Charles Edison became board chairman of the merged company until he retired in 1961. Max McGraw was chief operating executive.<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-2" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup> In March 1957, McGraw-Edison acquired Griswold Manufacturing. Griswold manufactured cast-iron cookware and some electrical items. Later that year the Griswold brand and housewares division were sold to the Wagner Manufacturing Company of Sidney, Ohio.<sup id="cite_ref-FOOTNOTEGriswold_History_4-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[4]</sup> In 1959 Al Bersted became president of McGraw-Edison with responsibility for day-to-day operations. Max McGraw continued as chairman of the executive committee.<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-3" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup>
McGraw-Edison took over the power tool businesses of General Electric in 1969 and of G. W. Murphy Industries in 1972.<sup id="cite_ref-FOOTNOTEMcGraw-Edison_Co.:_VintageMachinery_5-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[5]</sup> In September 1979 McGraw-Edison purchased Studebaker-Worthington, a company formed from a merger of Studebaker and the Worthington Corporation.<sup id="cite_ref-FOOTNOTEStudebaker_History_Timeline_6-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[6]</sup> The auto-maker Studebaker had founded in 1852 as a blacksmithing and wagon-building company by Clement Studebaker and his brother Henry.<sup id="cite_ref-FOOTNOTEErskine191815_7-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[7]</sup> Worthington had been founded by Henry Rossiter Worthington, the inventor of the direct acting steam pump.<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-4" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup> The two companies had merged with Wagner Electric in 1957 to form Studebaker-Worthington.<sup id="cite_ref-FOOTNOTEChurella1998144_8-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[8]</sup> The purchase more than doubled the size of McGraw-Edison.<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-5" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup>
In June 1980 Bastian-Blessing, soon to merge with Nytronics, Inc., acquired McGraw-Edison's food service equipment division.<sup id="cite_ref-FOOTNOTEBastian-Blessing_Co..2C_Nytronics..._9-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[9]</sup> Around the end of 1981 the company sold its power tool division to Shopsmith, Inc.<sup id="cite_ref-FOOTNOTEMcGraw-Edison_Co.:_VintageMachinery_5-1" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[5]</sup> McGraw-Edison manufactured equipment such as air conditioners and humidifiers at their 24 acres (9.7 ha) site inCalhoun County, Michigan between 1958 and 1980.
In the last decade of operations the company spread about 15,000 US gallons (57,000 l; 12,000 imp gal) of oil waste contaminated with trichloroethylene (TCE) to control dust on the site's dirt roads. In 1980 TCE contamination was found in nearby residential and municipal wells. The State of Michigan and McGraw-Edison Corporation registered a consent decree on 11 June 1984 for clean-up of the contaminated soil and groundwater.<sup id="cite_ref-FOOTNOTERegion_5_Superfund:_McGraw-Edison_10-0" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[10]</sup>
McGraw-Edison was acquired by Cooper Industries of Texas in 1985. At the time of the take-over McGraw-Edison had 21,000 employees working in 118 facilities in the United States and other countries.<sup id="cite_ref-FOOTNOTEMax_McGraw_Foundation_1-6" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup> Cooper took over responsibility for the Calhoun County site clean-up and as of 2004 the remedies were functioning well.<sup id="cite_ref-FOOTNOTERegion_5_Superfund:_McGraw-Edison_10-1" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[10]</sup>
Hotpoint
So GE acquired Hotpoint by 1918 !!
Ahh Robert et al  at Applianceville --  I tend to doubt the factoid "1965 Hotpoint creates the first gentle action agitator washer" My 1961 GE is an agitator washer and has a low speed !!!
In 1903, Earl Richardson, a meter reader and plant superintendent for an electric power company in Ontario, California, developed a small, light-weight version of the heavy, cumbersome electric iron first patented in 1882. Richardson's invention was eventually named Hotpoint, after the heating elements that converged in the iron's tip, allowing it to be used to press around buttonholes and in and around ruffles and pleats on clothing and curtains.
Meanwhile, George A. Hughes, a 33-year-old former journalist from Iowa, was experimenting with the first electric range. The model was crude, with simple heating element wires set in clay bricks that burned out after only a few hours of use. After a few years of trial and error, Hughes created the electric range what would revolutionize the way we cook in our home kitchens.
In 1918, Richardson and Hughes joined forces, merging their companies with the General Electric Company, and creating the Hotpoint brand of appliances. Throughout the remainder of the decade, Hotpoint launched many appliance industry firsts:
<ul style="margin: 25px 0px 80px 45px; padding: 0px; border: 0px; vertical-align: baseline; list-style: none outside; color: #555555; position: relative; font-family: Arial, 'Lucida Grande', sans-serif; font-size: 13px; font-weight: normal; line-height: 18px;">
<li style="margin: 0px 0px 15px; padding: 0px; border: 0px; vertical-align: baseline; list-style-type: none;"><strong style="margin: 0px; padding: 0px; border: 0px; vertical-align: baseline; line-height: inherit;">1924</strong>: First all-white, fully enameled electric range.</li>
<li style="margin: 0px 0px 15px; padding: 0px; border: 0px; vertical-align: baseline; list-style-type: none;"><strong style="margin: 0px; padding: 0px; border: 0px; vertical-align: baseline; line-height: inherit;">1950</strong>: First electric "moistureless" clothes dryer.</li>
<li style="margin: 0px 0px 15px; padding: 0px; border: 0px; vertical-align: baseline; list-style-type: none;"><strong style="margin: 0px; padding: 0px; border: 0px; vertical-align: baseline; line-height: inherit;">1953</strong>: First refrigerator on wheels, designed to make it easier to clean behind the refrigerator.</li>
<li style="margin: 0px 0px 15px; padding: 0px; border: 0px; vertical-align: baseline; list-style-type: none;"><strong style="margin: 0px; padding: 0px; border: 0px; vertical-align: baseline; line-height: inherit;">1961</strong>: First 90 Day Replacement Guarantee of Satisfaction allowing any customer who is not satisfied with the performance of a Hotpoint appliance to replace it with a comparable model.</li>
<li style="margin: 0px 0px 15px; padding: 0px; border: 0px; vertical-align: baseline; list-style-type: none;"><strong style="margin: 0px; padding: 0px; border: 0px; vertical-align: baseline; line-height: inherit;">1965</strong>: First low-speed agitation clothes washer, making it possible to machine wash clothing such as delicate lingerie, synthetics and cashmere sweaters which previously had to be washed by hand.</li>
</ul>
http://www.hotpoint.com/hotpoint-history/
Theory
Hotpoint must have been operated as a separate division which contracted its manufacturing out. Hotpoint must have contracted with Beam and also maybe improved on the patents Beam was using? And they used GE's legal office to file their improvements. As long as Hotpoint contracted with Beam the patents could be used?
I think Speed Queen had some of thier own manufacturing but probably started out sourcing from Beam. Maybe by the time Speed Queen was acquired by McGraw-Edison the first patents were running out or maybe GE sold them to Beam or SQ ?
But that improved Fluid Drive didn't expire until 1967.
Patent Exhaustion Doctrine
This might be what happened to those patents:
The exhaustion doctrine, also referred to as the first sale doctrine, is a U.S. common law patent doctrine that limits the extent to which patent holders can control an individual article of a patented product after an authorized sale. Under the doctrine, once an unrestricted, authorized sale of a patented article occurs, the patent holder’s exclusive rights to control the use and sale of that article are exhausted, and the purchaser is free to use or resell that article without further restraint from patent law. However, under current law, the patent owner retains the right to exclude purchasers of the articles from making the patented invention anew, unless it is specifically authorized by the patentee.<sup id="cite_ref-1" class="reference" style="line-height: 1; unicode-bidi: -webkit-isolate;">[1]</sup>
Procedurally, the patent exhaustion doctrine operates as an affirmative defense, shielding authorized purchasers from infringement claims concerning the use or sale of a patented good after the patent owner authorized its sale.
Because the doctrine is only triggered by a sale authorized by the patentee, it is often difficult to figure out if the exhaustion doctrine applies in a particular case, for example, when the patentee restricts or conditions the sale itself, or restricts the use or sale of the patented article once purchased and in the hands of an end user (post-sale restrictions). The 2008 Supreme Court decision in Quanta Computer, Inc. v. LG Electronics, Inc., leaves unclear the extent to which patentees can avoid the exhaustion doctrine through limited licenses. Since its development by the courts in the late 19th century, the patent exhaustion doctrine has raised questions regarding the scope of exclusive rights granted by patents and the extent to which a patent owner may extend those rights to control downstream use and sales of patented articles.
Holy Cow
Just stumbled upon the Internet Archives - they have all the Official Gazettes for patents on microfilm - online!!
In 1956 GE was offering many patents for sale or licensing so I think I found the answer- GE must have licensed/ sold the Hotpoint Patents at some point to Beam. It will take a lot of digging but I need to know when Beam ceased production. That point would be the starting point to look back from.
Speed Queen is too vast over time to search for.
http://https//archive.org/stream/officialgazette712unit#page/n1/mode/2up
So where does the dual motor Coronado fit into this picture?  I believe that it is mentioned in the linked thread that the owner's manual is 1948, well before Hotpoint and Speed Queen had automatics.  Was Beam licensing the GE patents back in the 40's, or is this pre-GE owning the patents and pre-Beam all together, and it is a Solar made machine?
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?29325
If I understand the first-sale doctrine, it applies only to actual physical articles that incorporate patented technology, not the patents themselves. So I don't think that related.
Well Ben !!
When I saw the 2 motor patent I didn't actually think they ever MADE that machine! Now we know they did and why Robert was puzzling over-
"There seems to be two different distinct eras of the Beam Line, the earliest from 1947 thru 1953 lines and the 1954 thru 1957 lines. "
So the one motor machine was applied for in late 1940's and granted 1950 so they obviously converted over to the new simpler machine by 1954.
But they are still all GE patents not Beam. Now were Beam Vacuums still Beam after Franklin  bought them out?? I never heard of a Franklin vacuum.
Oh it just gets more tangled !!
This is the kicker - "Then it appears that sometime in the mid 1950's Franklin bought out Beam and in 1958 started to manufacturer the "pig" style Franklin machine complete with the indexing tub. Its also very interesting that in all of this literature Speed Queen was never mentioned even though Speed Queen was the King of Beam made automatics all the way through the 60's."
Thank you Cornutt, after a second reading I concur with your analysis.
Indexing tub.
I remember reading here the early TL Westinghouse, was an Easy, iirc.  What year did WH.  begin production of their own TL?  Did the early WH.  TL's made by WH.  index?  arthur
Westinghouse top loader
In 1961 WH bought 20,000 top load automatics from Easy and rebadged them Westinghouse ( dealers were demanding a top loader to keep up with competition). In 1964 WH developed its own top loader called "CPA" (center post agitator). I am guessing, because it was totally redesigned, that the tub indexed. Jeb
Indexing tubs
were a  totally Westinghouse design they even made it into the "Frigidiare's-in-Exile" models after GM dumped Frigidiare.
Oh Ben I forgot to mention the two motor patent was ALSO held by GE. I think the closest they came to that was in Roberts early GE it has two motors for the pumping and draining. But only one motor to drive the beast.
Indexing tubs
Were a Franklin innovation as was stated in or around 1958 [ see reply #23 ], WH did not come out with an IT washer till 1964, 5 or 6. The Frigidaire IT washers after 1980 were PURE Franklin they had little to nothing to due with the WH IT TL washers.
Great information Jon, thanks for all your research, John L.
A new find !! Castner maybe the key
I have to read these patents in detail to be sure --
Castner worked for SOLAR Corp Webster, Iowa  in 1946 and now I find Solar Corp might have become part of or bought out by Gamble Skogmo by 1951 ! Because Castner's next patent "Snubbing Mechanisms for Gyrating Extractors " was granted granted in 1951 under Gambles-Skogmo it looks like   the <span style="font-size: 12pt;">"Beam" Snubber used in all Beam and Speed Queen machines !!</span>
<span style="font-family: arial, helvetica, sans-serif; font-size: 12pt;"> </span>
[this post was last edited: 8/10/2014-10:13]
http://https//www.google.com/patent...a=X&ei=XH_nU7eNPMKcyAS9kIH4BQ&ved=0CDMQ6AEwAw
