A Dutch newspaper ad with a 1957 Frigidaire Unimatic in it
foraloysius
Silver Member
May 21, 2001
12,846
Leeuwarden, Friesland, the Netherlands
Robert’s thread about the introduction of automatic washers in the newspapers made me have a look again at the Dutch archives. I have posted a few threads with Dutch ads in the past. The first ads are from 1953. I looked a bit furder and much to my amazement I found a 1958 advertisement with a 1957 Frigidaire Unimatic in it. Apparently this model was sold in the Netherlands.
    569.6 KB
    881.3 KB
I have no idea how many Unimatics were sold here. This is the first time I have seen an ad with this machine. Actually the same ad turned up a few times more, also in 1959.
Westinghouse frontloaders are the most advertised American washers. But GE and Bendix were sold here too in the fifties. I never saw those on auction sites so finding a Unimatic here would be a real miracle.
I bet that 50Hz Unimatic would dry even faster if run on a 240 volt 60Hz supply. ;)
I wish the US would had gone to 220 volts at some point. If not 60Hz, 50Hz would have worked too but as long as it was somewhere between 220-240 volts. Preferably derived via two hot conductors but thats just me.
220-240 volts would have allowed for high powered heaters in front load washers and dishwashers making for faster, more efficient front load washers. Including the possibility of cold only hook ups. Appliances like dryers, stoves and ranges would be simpler by not having 120 volt components. And of course none of that grounding through the neutral stuff would ever have been likely.
FWIW, this is how I imagine an electrical panel in the US if everything was all 240 volts. 20 glorious double pole breakers 🤩
(Click to enlarge the pic)
    267.6 KB
The North American electrical system and grid is a lot more flexible, can have 120v in your home and have 240v at your disposal when extra power is needed.
Certainly a lot safer since higher voltages carry more current which is no good in regards to safety and so forth.
Oh, most homes in the US have 200 amp service which leaves one with a lot of power at your disposal, pun intended.
Not to mention, higher powered appliances encourages one to be wasteful since there’s more power available. When you only have 120v available with 15 amps available, forced to be mindful in regards to power consumption.
I once had an argument with chicken farmer in Delaware, who insisted he'd been "an electrician all his life". He was certain that a 220V air conditioner was less expensive to run, because they drew less amps. I attempted to explain that the power company doesn't charge for amps, it charges for watts. Since we were looking at a 14,000btu 110V air conditioner at the time, I told him that unit was absolutely less expensive to run than a 220V equivalent, which would likely have pulled close to 2,000 watts... we nearly came to blows. (ok, hijack over with!)
Why would you need 120 when 240 can and will work for everything as already proven everyday across 90% of the world?
Being able to drive more current through any given resistance means short circuit and ground fault current has a greater probability of being above a circuit protective device's minimum threshold. Higher currents result in substantially faster opening of circuit breakers and fuses.
And not to get to technical, but since any given device is now drawing half the current at double the voltage there is a good chance the breaker or fuse will match that. A 10 amp breaker has a much lower minimum pickup threshold than a 20 amp breaker.
A 240 volt system gains at least 4x fault sensing acuity.
120 volts had forced front load washers to draw from a storage tank where as it has been proven that heating the water in the machine is more efficient over-all.
Wow that 1956 ad you posted Louis, seems like the 1950-1954 model design was still being produced in the Netherlands as late as '56.
I posted that image into AI and had it translated...
THIS IS THE AUTOMATIC WASHING MACHINE FRIGIDAIRE
All you have to do from now on:
SET ONE SWITCH ONCE
Frigidaire quietly takes care of the rest:
  • washes without wear
  • rinses everything completely clean
  • dries as if air-dried
All in one easy motion! Let Van Boxtel tell you everything about this masterpiece from General Motors. Let Van Boxtel demonstrate Frigidaire.
You will see that, without wringing, without rubbing (thus without wear), your laundry will be thoroughly clean. You will be amazed at how little work Frigidaire saves you — in less than half the time it used to take!
FRIGIDAIRE AND VAN BOXTEL — these two names are your double guarantee.
VAN BOXTEL
For 50 years known for reliability, craftsmanship, and service
The Frigidaires sold overhere were probably imported from the USA like other American whitegoods.
Frigidaire was especially well known here for their fridges. The Dutch word “koelkast” wasn’t used much. A lot of people used the name Frigidaire (pronounced in French!) for the product, even when it was another brand.
Oh, it looks like brisnat81 decided to laugh at my post for no apparent reason.
Go ahead and complain, but can clearly see who likes and or reacts to posts. Can’t hide anymore on this new site.
Reply number eight chicken farmer from Delaware.
You could tell he didn’t know what he was talking about because there’s no such thing as 110 V or 220 V in this country. I’m always amazed how many electricians don’t know their stuff.
Yes, you’re charged by watts not by the number of amps something draws although in many cases, the 240 V air conditioners do cost more to run because they often were less efficient because the manufacturer of the air conditioner had more power to play with on a 240 V circuit.
However, properly built equipment there’s no difference in operating cost between 120 or 240 V, a lot of the most efficient equipment on the market today is 240 V just because that’s where the emphasis is.
John L
Meanwhile, back two unimatic washers in the Netherlands.
I would agree that it’s likely these machines were made in the US.
It would be interesting to know the spin speed and agitate speed of the models made for 240 V sold in the Netherlands, I’m going to bet that it only spun at 970 RPMs and it may have agitated more slowly too unless they changed the gear ratio for the agitate drive in the transmission.
It would’ve been very costly to make a 50 cycle motor that spun at 1140 RPMs for such a small number of machines that were probably sold there. If they didn’t change the gear ratio, it would agitate at about 280 strokes per minute, which would probably still work fine who knows it may not even tangle as much.
John L
John,
Robert mentioned a 50Hz/220 Volt motor in his first response, so who knows. Nowhere in the ads a spin speed is mentioned so we can only guess about that.
To end the story about the American Frigidaires in the Netherlands, 1960 is the last year the American set is shown in an ad of the Aline. Two more ads I want to share, both small ones. The first is a different ad in which is mentioned the Aline has it’s own heater, gas or electric. The second is an ad from 1964 with the Frigidaire Alimatic, a fully automatic machine, also made in France I presume.
    240.2 KB
    316.7 KB
All of the Aline Frigidaires shown in Louis's ads have the lid offset to one side.
Would that be correct? it looks odd.
I wonder, were they up-and-down Frigidaires or maybe French-made top load tumble washers rebadged as Frigidaire??
As an aside to Louis, (hopefully not another hijack...;)) my partner and I went to Indonesia recently, for 3 weeks. We learned a little more of the connections between Dutch language and Indonesian. When I studied Indonesian language in the 1970s and 1980s, the word for refrigerator was "lemari es" which translates to English as "ice cupboard." But Indonesian has changed a lot since then, one change is they have adopted the Dutch word you used above, "koelkast" but in Indonesian it is written "kulkas." The pronunciation would be the same, except the "t" on the end has disappeared.
So today, stores advertise Kulkas, not lemari es.
Indonesian used the Dutch system of orthography (which sounds are represented by which letters) until the mid 1970s. Malay, which is a very similar language, used the English orthography. The two nations Indonesia and Malaysia adopted a new shared orthography, which made it easier for the two neighbouring countries to communicate and replaced the spelling systems of their two previous colonial powers. This is why the "oe" from Dutch (and old Indonesian) is now written as "u" in modern Indonesian.
John,
According to the math a 6 pole motor spins at 1140rpm on 60hz and around 950 on hz, which includes motor slip.
My ignorance will show at this point onward. 😳
But how many poles are in a Unimatic motor and is there any type of mechanical speed reduction mechanism like gears in the Unimatic system? I've never seen or taken apart a Unimatic in person.
Unimatic washers use a 6 pole AC induction motor, most other washers of that time use a 4 pole AC induction motor. The gear reduction is only done for agitation/pulsation, spin is directly the same speed as the motor.
That is an elegant way of doing it.
I stand corrected, it is very possible that EU Unimatics were not speed compensated for 50Hz power like I had originally assumed in post #4. In that case the spin and pulsation would indeed be slower at 220 volts 50Hz and normal at 240 volts 60Hz. I am hoping at least the timer was speed compensated considering the timed fill and all.
