Six months ago I had purchased what I thought was a nice Maytag SAV (Amana-tag) TL washer that appealed to me because of the robust suspension. It already started leaking from the outer tub and I am following the consensus which was to cut my losses.
Now I just purchased a Kenmore 80 series that I hope to have better luck with! It no longer has the model # tag but I believe it was made somewhere in the 2000-2003 era. I’ve been reading past threads and I’m getting ready to buy a spanner wrench so I can pull the inner tub for a deep cleaning. I also will be working on some rust areas and paint touch up.
I ran the first 4 or 5 medium size wash loads through it yesterday to see what I have to work with; and would like to see what you think about the neutral drain.
First I believe the timer is advancing AND pausing consistently like it should after each part of the cycle. I ran my first load on the “Regular” cycle and noticed after the agitation (and short pause) that the tub started it’s spin just as soon as the drain started. Moving on to after the rinse cycle was complete, it did the same thing again. Not looking good.
Next load I used “Perm. Press” to see if that made a difference. After the washing (and pause) the drain and spinning starting again together. At this point we are 3 for 3 the neutral drain (ND) not working. However, after the rinse cycle I was very surprised when the machine completed the ND just like it was suppose to. Then it paused and started into the spin cycle like it should.
Now I’m confused so I ran another load on “Perm. Press”. This time the ND worked perfect on both wash and rinse!
I took an hour or two off for lunch and on the next cycle the ND didn’t work again after the wash phase, but worked perfect after rinse. By now I’ve read more here and learned how to test the machine without doing full wash cycles. The next four test the ND worked perfect each time!
Here is what I’m thinking. The washer had sat in my van for over night and the temps were in the mid 40’s. It was up to about 52 - 56F in my garage when I was testing the machine. Perhaps the gear oil was too cold / thick and it took a bit of work to get it warmed up. Therefore ND may work consistently when the washer is inside at more normal temps.
See the second picture of the underside with the oil spray line on the inner housing. That is how I got the machine but I cleaned that all off, and there was no more oil that has showed up so far. Still that oil concerns me since I do not know the history.
1. I’m going to be pulling the tub to do the deep cleaning, so should I just plan to open the transmission to replace the gear oil – or wait to see if the ND works again on a few more test loads and, if so, figure it’s all good for now? I’m thinking no need to install the 388253 ND repair kit unless we are sure there is a problem ?
2. I do have a small leak from the pump so that will be replaced. I was surprised to see there are dozen's of “brands” of pumps offered on Amazon, but I plan to purchase one from an appliance store so that I have a chance to “get it right the first time”.
3. If anyone knows why there is a small foam “belt” around the brake housing I would like to understand what that is for (picture #3 immediately above the yellow spring).
4. Also, why do they all have that piece of white cardboard mounted to the bottom side of the motor?
