turquoisedude
It was a long weekend here in Quebec (the St-Jean-Baptiste Holiday weekend) so, guess who was busy messing around with vintage laundry equipment??
First up: the 63 GE V-12 washer. I finally got the leak on the filter-flo recirculation hose patched (a new one is on the way, but well, I an anxious to get this one into the Ogden Laundry!). However I ran into an issue with the water valve. Thanks to experience and the Repair-Master for GE Washers, I figured the problem might be due to a foreign object blocking the valve or a damaged diaphram.
Luckily, it was the former not the latter. After a good cleaning, the valve was working reliably once again.
