potatochips
- Joined
- Sep 9, 2016
- Messages
- 545
This popped up on Kijiji for $20, couldnt lose. Its a TOL Canadian filter flo from April of 1993, just before NAFTA became a thing. I wanted this machine since it was unique, being TOL, and since I was also looking for a machine with a good outer tub and transmission.
However, as you will see in the pictures, the transmission post is rusty and starting to flake, and the tub support is rotten. One of the tub nuts in the support is only threaded in by a minute amount of thread. Im sure if I was to reassemble it, id only be properly threaded in to two of three bolts. The transmission is also leaking oil. AND furthermore, the transmission will bind up in agitate mode if you spin the tub clockwise... Needless to say this transmission is no good.
The good is just about everything else, clutch, basket, controls, top. Minimal, and I mean minimal, rust. I do need a four position water level switch though. The owner didnt have the minibasket or the filter pan.
Check out the basket though, white.
