For Bud (and all others)
Here is what I could hear (some portions were hard to find out with all the noises. I am not 100% sure about the wording but at least it will give you an impression).
Joe
transscript:
Hello and welcome to a new demo.
(SUBTITLE: Presentation)
It's the "Vedette compact 655", a real 6 kg machine that came out in 1965 / 1966.
(SUBTITLE: Loading the wash)
Closing is really simple, the detergent compartment is at the front. A really big soap box, that is...
(SUBTITLE: about filling in detergent and about the controls)
How it works:
Well, this is the "spin" button for cycles that need spinning,
"rinse & hold" button: the machine will stop after having filled to low water level after the second rinse so you can add some chlorine bleach,
"delicate" button for a slower wash action and a higher water level,
and finally the start button and the cancel-all button.
Here is the thermostat going up to real 100°C (boiling point)
two pilot lights as we will see, one for filling, one for heating
(SUBTITLE: Starting it up)
We will start filling it up for a wash cycle of 50°C with spin.
You can hear the timer motor really well ...(muffled sound).. micro... (muffled) ...likewise....which is part of....(muffled or microphone covered)
(SUBTITLE: controlling wash time)
Here we go: Filling has ended. We can hear the switch for the heater and the corresponding pilot light goes on. That means: Now we can choose the wash time, here it is at 40 mins...
Apparently it was necessary to get familiar with this machine in order to choose a wash time that was sufficiently long to allow for a proper heating so that the chosen temperature could be reached.
And the user manual would give you a time table with the approximate values for this; As you can see: Chosen temperature, setting of the thermostat and minimum timer minutes that are necessary.
(timer advances): see!
Now there are about 6 mins wash time remaining
and you can see these typical little droplets on the lid.
The rotation of the drum is relatively slow at 30 rpm compared to later machines with their 50 rpm, likewise the spin speed is fairly slow with its 300 rpm.
(SUBTITLE: stepping of the timer, draining the suds)
Now pumping out the wash suds, well, each timer step is about 3 mins.
(SUBTITLE: beginning of first rinse)
(SUBTITLE: intermediate spin)
The balancing system: Little rollers help to counteract the forces of an unbalanced load. (my note: not 100% sure about this one)
(SUBTITLE: Quick advance of timer with spin button in OFF position)
We are coming to the end of the draining phase and as spinning is selected off...
(SUBTITLE: Final spin)
(SUBTITLE: fluff-up / anti-wrinkle)
Loosening the clothes after spin takes about 3 mins which corresponds to one timer step.
Here we go, the cycle has finished.
(SUBTITLE: Bonus)
And here is a little bonus: We're about to see a cycle at boiling temperature to give us a chance to see these marvellous little droplets on the lid, a nice remembering of childhood times.
(SUBTITLE: 60°C)
We are amidst a heated cycle....the temperature now having reached a little more than 60°C. You can already see those bubbles forming.
Now a bit more than 90°C.
(SUBTITLE: 100°C)
We are coming to the boiling point, the steam is coming out at the edges of the lid and unfortunately you don't have this childhood smell of a real bubbling laundry bath. The heater has turned off now which means that the boiling point is reached.
The lid is searingly hot.
Towards the end of the wash cycle the heater turns on again. That shows how effectively the thermostat works, due to a drop of the water temperature.
We are approaching the end of the cycle.
Now it's finished.
See you soon for a new demonstration.
