jetsystem1200
- Joined
- Aug 9, 2011
- Messages
- 104
Hi! You may not have seen me around the forums before as I mainly read rather than post. Let's start with what happened to our old dryer. After 13 years of heavy use especially during winter, our Zanussi TC481W dryer finally broke down when the timer broke and the drum wouldn't turn during a drying cycle. We needed a new dryer anyway as the TC481W has a 4.5kg drying capacity and our Zanussi FJD1266W washer has a 6kg capacity. Then after a trip to the worst appliance stores in the world (Comet and Currys), we finally bought the Zanussi ZDC4700W condenser dryer. It had to have a large capacity, sensor drying and a water tank on the bottom since we have our dryer stacked on top of our washer. The Zanussi ticked all of those boxes with a 7kg capacity and a water tank behind a cover on the bottom. As for the sensor drying, it has 4 sensor cycles. Cottons cupboard dry and extra dry and the same for synthetics are the sensor cycles. It also has timed cycles ranging from 40 minutes to 150 minutes. It also has a cool programme for the kits that you use to dry clean in your dryer (Dryel, I think it is called). I dried some towels in it today and the sensor cycles are very quick and the sensor is not too sensitive. The lint removal is EXTREMELY good, as I had blue lint about 1cm thick on the filter. The condenser is very easy to clean, but the water tank is very small. Overall, it looks to be a good dryer for us.
