jim
Gentlemen, I have bought a 1-18 this morning. I saw it on Craigslist. Called and emailed the people yesterday mid-day and they got back to me - seems it is an apartment/rental house company that had this in one of the houses they just purchased and will be renting. They thought the machine was too old and replaced it. I went to look at it yesterday afternoon after work. Even though it looked a bit worse for the wear with the bit of rust around the holes for the screws on the front panel and a loose control panel, it still was worth $35.00 I thought. I've posted pics on my photos (opened to view). Haven't done a thing with it yet but I was told that it worked.
The front cover was off - missing screws at bottom. The control panel was loose also but just another loose screw. The rubber seems to be pliable and in good condition. When I moved it today, there was still a bit of water in the pump. I saw no evidence of oil being splattered on the inside of the cabinet - but I did see a small spot of what looks like debris from an old belt. I looked at the belt on the machine and thought it looked pretty new and it turned easily and I saw no evidence of wear. The hose leading to the pump and the exit hose are in fine shape - very supple. The rollers are all in place and feel grease free and very much like a brake pad on a car. We'll see. (I haven't told my partner about this yet. I did however, just to appease the washer gods, put the Speed Queen Wringer Washer out for the trash. Maybe someone will grab it. I was told the last time I brought a washer into the house that I had to get rid of one other one before I could have another. Well, I'm selling an older Frigidaire refrigerator to make room for this.)
The glass in the lid is in tact. A bit of rust here and there in the corners at the back and one of the side panels is a bit bent, but nothing too major that a bit of elbow grease et. al won't fix. The base is in fine shape, motor, pump mechanisms all seem to be there.
It allows control of wash temps and rinse temps. I like that. I couldn't get the top of the tower off though. Any suggestions? The filter was clear. I found no lights inside the tub area. No backlights on the control panel. A bit of paint gone from the panel - matte black shouldn't be hard to re-do. I have to go buy some hoses long enough to connect to the spigots ungerneath the laundry sink and extend the drain hose. And a couple of splitters with shut off valves - one for each washer. It needs to be screwed back into place (maybe I'll use ss nuts and bolts to hold the front panel on.) But I want to do a full cleaning first. The whole thing needs to be dissasembled and scrubed down. And after the cleanup the front panel needs to be coonnected securly to the base - it looks like it could be pretty woobly without some tightening up first. It's exciting to get something like this for $35.00.
