A Royal Restoration - Summer of Love Speed Queens!
swestoyz
Sep 27, 2004
6,634
Cedar Falls, IA
Evening, fellow AW collectors! I wanted to provide an update on a set that I had posted about back in 2021, shortly after they were delivered. The preliminary check of both looked promising, but after pulling the top off the washer the tales of a blown out balance ring were quickly discovered. I was then on the hunt for a donor tub or balance ring, as well as a base as both front legs had sheered off due to extensive bleach damage.
Original posts:
They’re here! 1967 Speed Queen set
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?88738
Speed Queen Balance Ring Woes:
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?90084
This is a very long thread so if you’re not digging the extra detail on the restoration feel free to skip down to the end for the glamor shots and video!
The Dryer
Once it was determined that the washer wasn’t in a great position to begin a full restoration, my attention was switched over to the dryer in early 2022. Thankfully everything on the dryer was in really nice shape. While most of the parts could have been reused the dryer did receive new drum and door seals, a new drum and blower belt, new front rollers, and a good overall cleaning. The original terminal block was disintegrated and was replaced with an over the counter Whirlpool part.
The dryer took a few weeks to go through and was installed roughly a year ago and has been used as a daily driver since. It’s a great performer when compared to other dryers being made in the mid 60’s, although the lint filter is a bit messy and leaves lint deposits on the wire frame that holds the filter. Performance wise it’s between an HOH Maytag and a GE, and built like an absolute tank and QUIET. The auto dry cycle is quite accurate and rarely does anything need additional attention.
The pretty stainless drum is really the main reason why I decide to go forward with going through this dryer completely and using it as a daily driver.
Here’s a list of the parts that were replaced with new:
Outer door seal - 51799 (tough to find)
Inner door seal - 51798 (still somewhat available)
Front drum seal - 51881 (band and spring were re-used, this seal is tough to find)
Back drum seal - 51883A (kit comes with a new band and spring -getting harder to find)
Drum belt - 52556 (plentiful w/ generics available)
Blower belt - 51994, generic is a 3L460
Drum roller - 56285 x2 (if replacing original style two piece rollers, new hex nuts and split washers will need to be procured from your local hardware store for the 52685 rollers)
Terminal block - 50854, subs to FSP WP33001244
Full tear down
About 4 years ago I had found a barely used 1972 reversing motor SQ in a defunct appliance store/hoarder building. While many items had been robbed off of it over the years for service calls, it was a totally rust free and mint avocado DA6071. That washer was restored in the summer of 2019 and went to go live with a fellow collector shortly afterwards. Fast forward to January 2023 and the green Queen was brought back to Iowa to be a full donor for the ’67, providing the critical tub/balance ring as well as a rust free base frame.
With the ’72 disassembled it was time to tear down the ’67. Once the tub and outer tub have been removed the full mechanism can be pulled from the frame by removing the snubber suspension system and lifted up out of the rubber isolator in the base. From there on the disassembly of the mechanism was done on the work bench. This task is so much easier to do outside the machine!
Main Bearing Assembly
During the initial testing of the washer it was evident that something wasn’t quite right with either a bearing in the main bearing assembly or a seal. There was a high pitch squeak that would start once the tub was up to full speed, after things had warmed up a bit. Tearing the assembly apart was also motivated by the need to swap out the factory spin pulley over for the high speed commercial pulley that I just happen to stumble upon shortly after finding the ’67 washer.
With the machine torn down the first thing I noticed was excess soap caked around the upper portion of the housing and excessive gunk up by the upper seal. After disassembly it was clear that the seal rubber was starting to break down and wear on the mating sleeve on the drive shaft. If this had been used as it there’s a good chance the seal would have eventually failed.
After getting everything cleaned up I coated the upper portion of the housing with that awesome epoxy sealer I used on the interior of the Bendix pump, hopefully preserving it receiving any further damage moving forward. Brand new SKF doubled sealed bearings were installed to replace the single shielded originals, along with a brand new substituted upper lip seal. I’d suggest going this route for anyone restoring a 1960-1980 solid tub over using an NOS 21659 lip seal, as the few NOS seals I’ve found aren’t nearly as nice as the cheap double lip seals you can buy today.
Ball bearing - 20012 x2, sub’d for SKF 6206 2RSJEM double sealed bearings (30mm x 62mm x 16mm)
Commercial spin pulley - 24625, replacing the original 20130
Upper water seal - 21659, sub’d for a 35mm x 62mm x 10mm double lip seal
The Transmission, Part 1
With the bearing assembly checked off the list, the next logical item to tackle was the transmission. I was hesitant to even bother as it sounded as quiet as could be during the initial testing. But, knowing that everything else was going to be attended to I decided it wouldn’t hurt to crack it open. The original gear oil was just at the beginning stages of breaking down and turning into sludge. So, everything ended up in a bucket of mineral spirits and cleaned. Lots of date stampings for ’67’, even with one indicating May. That is the newest of the many date stamps found throughout the washer, putting this machine right in line for assembly in Ripon, WI during the Summer of Love.
Anyway, before assembling the transmission I had made the decision to use Redline MT-90 to replace the gear oil in the transmission. A few collectors had good luck using this in Maytag transmissions and it is highly rated in the automotive world as a GL-4 synthetic equivalent, for use in manual transmissions where a GL-4 gear oil is required over a GL-5. The problem was SQ never published the type nor quantity of gear oil they considered for the transmission, nor could I find an original bottle of 02528 transmission lubricant to see what the amount was for ‘one fill’. The decision was to fill it up to where the original oil appeared on the drive gear, which came out really close to about a quart.
The original 20199 clutch seal and 20220 pinion seal were replaced with new rubber coated lip seals. I couldn’t find a replacement rubber coated clutch seal that had the same height as the original, 7 mm, but the 9.5 mm height of a double lip seal mates up perfect along the OD of the clutch. The fit of the new clutch seal is tight but it does fit within the cover recess, although oversized on the height side when comparing to the diagram in the service manual. The pinion seal can almost be pressed in by hand but should be carefully installed using a flat block of wood. Both seals are installed with the garter ring facing upwards, per the service manual and how the originals were also installed.
With the MT-90 topped off and new lip seals installed on the cover, the original gasket was cleaned and installed without any additional sealer, like RTV or rubber cement. The drive pulley was cleaned received a fresh coat of paint.
Clutch seal - 20199, sub’d for a 1.625” x 2.375” x 0.375” (1 5/8” x 2 3/8” x 3/8”) - rubber coated
Pinion seal - 20220, sub’d for a 0.625” x 1.125” x 0.250” (5/8” x 1 1/8” x 1/4”) - rubber coated
Mechanism Assembly
With the transmission and main bearing assembly completed the overall mechanism could be assembled and installed within the donor base frame. General assembly of the mechanism is pretty straight forward. SQ used a TON of threaded fasteners of different lengths so it does take a bit a diligence to keep track of which bolt goes where.
A rebuilt NOS A23669 fluid drive was installed on the motor, with the motor retaining the original motor pulley assembly. After several attempts of trying to drive the tapered pin out I decided to leave pulley alone as the clutch lining was in great shape. The belt groove of the pulley was cleared of old belt and oil deposits and the motor shaft was cleaned and lubricated with a light coating of Maytag SBL oil (sintered bearing oil, used on SOH dryer roller shafts). A clean motor shaft and t-bearing on the fluid drive are critical for correct operation. Gummed up or caked oil on the motor shaft or bearing surface can lead to coasting of the tub without the fluid drive engaged.
The original pump was intended to be rebuilt with a new seal and shaft/impeller assembly, but sadly the pump body was not in the great shape. Instead, an NOS A23302 pump was installed, although this pump did NOT have the fiber washer between the impeller and the body! If someone runs across a Beam style pump that has excessive play in the shaft, pull the pump cover off and check that the fiber washer is indeed installed. Another oddity about this replacement pump was the green coating that was applied at some point. I suspect this was done to help ward off mineral deposits building up inside the pump cavity.
The original belts were shot, as expected. An executive decision was made to try out some higher quality cogged belts (AX), rather than a standard non cogged belt (A). The belts used were Continental belts purchased from Grainger. The concern of gripping was at play due to the use of the smaller diameter commercial pulley, and the original SQ belt for the commercial pulley was an AX style cogged belt.
One small change to consider was the use of the commercial pulley. The original SQ belt, 20895, appears on a few interchanges as being a 25.5 inch belt, which is not common when going with AX style belts. So, I ordered both a 25” and 26” belt to see which of the two would work best with the 26” belt being the one that ended up on the washer.
After several tests on the bench (with the max RPM of the spin shaft coming out at 800 RPM!) the mechanism was installed in the donor base. The snubbers from the donor machine were used and the executive decision was made to retain the centering springs that were on the original ’67 machine over the counter balance weight from the reversing motor donor. Thankfully the holes required for the centering springs were drilled out on the reversing motor base (it appears that this base was also used on the 70’s solenoid drive commercial machines). All old grease was removed and all springs were installed using synthetic wheel bearing grease (green) from Lucas at each friction point.
Fluid Drive - A23669 / 23669 (these are getting harder to find)
Pump - A23302 / 23002 (plentiful. When shopping on eBay, make sure the pulley is a large groove pulley vs. the small groove pulley used on reversing motor machines. Both mechanism styles used the small cavity pumps)
Drive belt (commercial) - 20895, sub’d using an AX24 cogged belt, or 26” 4L style belt
Motor to Pump belt - 20185, AX26 (cogged), or 28” 4L A style belt
Pump to transmission - 20186, AX34(cogged), or 36” 4L A style belt
Mechanism Optimization, i.e. Fluid Drive fiasco
With the wash tub installed, I spent some time trying to dial in everything as close to perfect as possible. Belt tension between the motor and the spin pulley, and tension between the motor and pump, as well as the transmission were dialed in right around 1/2” deflection, as per the service manual.
What I was not expecting was the lack of hitting the advertised RPM of the 24625 commercial pulley, which was rated at 725 RPM, or 100 RPM over the rating on the standard 20130 domestic pulley. With the belts tensioned appropriately, the best the NOS fluid drive could produce was about 645 - 650 RPM, just roughly 20 RPM faster than the stock pulley!
At this point the motor was pulled and the fluid drive was drained. ~ 6 oz. of fluid came out of the drive, not the 7.5 oz as advertised on a full charge from the SQ fluid drive bottle. What gives?
After a lot of digging through various Beam related service manuals I finally stumbled across one service and parts manual that provided the factory spec - 6.5 oz! This was discovered in the 1949 Hotpoint Service and Parts manual. So, for any of us who have drained a fluid drive and only found about 6 oz in the drive, this was finally evidence that the oil did not “burn up” or leak out. This was the amount they were originally filled with! In the past I’ve drained two other drives and also go 6 oz out of them, and it appears others here on the board have as well.
So why would Speed Queen then sell bottles with 7.5 oz? While this is a hunch, I suspect they were aware of the overall efficiency of the fluid coupling within the fluid drive and had done testing later on to discover that these could be filled with a higher amount of fluid and still be able to work properly without stalling the motor and increase the overall torque potential for better spin performance.
With this in mind I also did some research on what the optimal hydraulic fluid ISO weight should be within a fluid coupling, and for industrial applications I found recommended anywhere between 10 and 15 ISO. The trouble is, finding a small quantity of hydraulic fluid with that low of an ISO rating is almost impossible, nor are the large gallon + sizes cheap. So, the next best option was to find any oil with the lowest rated ISO that is easy to find and test all options before I put the full machine back together.
Three oils were tested:
Zoom Spout oil - between 7.5 and 8 oz, 31.8 cSt at 40 deg C, or a 32 ISO rating
3-in-One Multipurpose Oil - between 7.5 and 8 oz, 23.31 cSt at 40 deg C, or a 23 ISO rating
Speed Queen Fluid Drive oil - 7.5 oz, unknown ISO rating
The first oil tested was Zoom Spout. Bottles can be purchased in 4 oz quantities so two bottles is necessary and can be found at most appliance parts or MRO distributors. This was the first oil tested after pouring out the original charge of 6 oz. from the NOS drive. The best I could get from Zoom Spout was roughly 675 RPM, with the belts pretty loose.
The second oil tested was 3-in-One Multipurpose Oil. This oil can be purchased at any local hardware or box store in either 3 or 4 oz bottles. I was surprised immediately with the 3-In-One as the RPM was starting to tip well over 700 RPM with a decent belt tension and close to 710 RPM with the drive belt pretty loose. This was starting to prove the theory that the lower ISO value could potentially produce a higher RPM speed, or was increasing the efficiency of the fluid drive.
The third oil tested was an NOS bottle of Speed Queen Fluid Drive oil. I had HIGH hopes for this oil, considering this is what would have been used when these machines were new and would have been used both on the domestic and commercial machines. Sadly, this was the most disappointing test! The best I could get the factory oil up to was roughly 645 RPM, almost identical to the factory change in the rebuilt fluid drive! Knowing that the performance was less than both the 3-In-One and the Zoom Spout, the Speed Queen oil is either an ISO of 32 or higher OR it does not age well.
I even tested the original fluid drive that came on the machine and was only able to get about 650 RPM out of it. Besides this being a very unscientific test it was quite evident that belt tension played a huge factor in getting a better RPM result, however the desire to not have belts that are ruined due to being overly loose is also a factor. It is also quite possible that Speed Queen’s advertised rating of 725 RPM was lofty, or the rebuilt NOS fluid drive I was using wasn’t as fresh as it could have been, or a mix of both. I also tried a variety of an NOS 20895 belt (it was a cogged AX style belt), the 25” and 26” belts and got the best performance out of the 26” AX cogged belt.
So, the rebuilt NOS drive was drained of the SQ oil and the 3-In-One oil put back in, but sadly with the multiple changes between all of the various oils, the best I could get at the end was about 685 RPM with good belt tension. I figured this was better than than the original factory speed and I didn’t want to tear the fluid drive apart just to clean everything in hopes of getting over 700 RPM again.
Long story short - if you’re working on any fluid drive Speed Queen or Beam related washer, a fresh charge of 7.5-8 oz of 3-In-One oil is a safe bet.
Cabinet and Top assembly
With all the testing and adjustments completed the rest of the machine could be assembled. Here’s a run down on the list of tasks that were completed during this phase:
Outer tub cleaning and POR-15 painted over rusted areas
Pump to Drain hose installed with the factory elbow installed on the base
Reused the 20129 outer tub boot from the donor washer
NOS 22337 bleach pump installed on base
Wiring harness cleaned / repaired and installed
Outer tub installed / cleaned 21233 outer tub gasket / installed wash tub from donor washer (agitator post assembly had already been cleaned / painted with prior restoration and new stainless button head hex screws where used to secure tub to center post)
NOS 25112 drain tub outlet hose to pump installed
Lid switch bracket installation - paint / new hardware
Cabinet panels cleaned / detailed / installed
Top panel disassembled / all parts cleaned / rust damaged patched w/ JB Weld and painted (pro tip - use a piece of blue painters tape on the side that needs to be flat. Once the JB Weld has cured pull the tape and paint)
NOS 24597 water valved installed (sub’d in place of a 22454/24596 valve, which I was unable to find, flow washer on 24597 is 0.3 GPM higher than factory)
Bleach dispenser parts cleaned and dispenser installed on outer tub. Use a cut piece of sheet rubber to tighten the fit around the bleach dispenser and coated the area around the dispenser w/ The Right Stuff sealant on the inside of the tub
NOS 22357 clothes guard installed on panel top
Cleaned rust stains from 23366 fill flume / cut replacement gasket from a piece of outlet foam sheet insulation
Removed peeling plastisol from panel support bracket and painted it grey
Removed old gasket from the agitator cap, cleaned cap, ran a die on the threads and installed NOS 20136 gasket
Cleaned hard water deposits and staining from original aluminum agitator
All the steps above were completed roughly over a two week period of time. With the machine mostly assembled (minus the front panel), it was time to test the fruits of my labor!
The Transmission, Part 2
So, after wheeling the washer into the testing spot in laundry room #1 and sorting out a few leaks, I threw a load of towels in the washer with some hot water. Immediately I could tell something was wrong. With each end of the stroke the transmission was emitting a loud clunk that most certainly wasn’t there when the machine was originally tested. While I considered for a moment that it could be the drive clutch or possible misalignment with the transmission to main mounting plate, but in my gut I knew it was the fluid inside the transmission.
After quick review of the service manual it appeared that the transmission could be removed with very little effort, and by gosh that is all it took! About 15 minutes after I had the back taken off the washer and removed the four mounting nuts, the transmission was laying on the ground and ready to spill the beans as to why it was sounding horrible.
Speed Queens may be the only top load washer that facilitates the removal of a transmission without having to perform major disassembly of the rest of the machine. A few other Beam related washers have various versions of the transmission and top plate integrated to the transmission, making a quick removal about impossible. I considered myself very lucky.
While on the bench, I temporarily reinstalled the drive pulley and slowly moved it back and forth to see if I could emulate the sound heard during wash, and sure enough I could get it clunk. With the cover off I could twist the pinion quickly in either direction to emulate the sound. Why was this happening?
When I had first disassembled the transmission I did the exact same thing I was doing now, but also I watched what the old oil was doing around the pinion and drive gear. Sadly I don’t have a video of this but the old oil would create a wave where the fluid would pool up over the pinion and fall back on the backside of the drive gear. With the Redline MT-90 oil I was not getting this same action and in fact the MT-90 oil would cause a vortex in front of the pinion that could potentially be reducing the film coverage between the pinion and drive gear. At this point I knew I was most definitely using the wrong oil, but what oil should have been used?
As mentioned earlier in “The Transmission, Part 1”, Speed Queen never publicized in either a service manual or parts manual what oil they were using in the transmission nor the amount, all the way from the 1953 A10 up through the last solid tub in 1980. Similar to the Fluid Drive fiasco, I started digging through all Beam related service and parts manuals to see if any one company accidentally spilled the beans as to the secrets of what these transmissions were originally filled with: Coronado, Hotpoint, Dexter, Speed Queen, Easy, etc. And what would you know, in the 1954 Easy service manual, or the first service manual Easy published for an automatic, they DID specify both the quantity and the type! Oops on them, but a huge win for us! All subsequent Easy manuals specified their proprietary part number, just like Speed Queen, LOL.
Finally, armed with the goods - 24 oz (or 3/4 quart) of 90 S.A.E. heavy oil. But wait a second, what exactly does 90 SAE heavy oil mean? And what does that mean in terms of say a GL-4 or GL-5, or a mix blend 75w90, 80w90, or 75w140? And does the context of the period have anything to do with this, as well?
I started digging through threads and posts here on AW about the ongoing debate of what oil Maytag used in their transmissions. The oil I scrapped out of the SQ transmission was very similar to OEM Maytag oil (thick, sticky, and almost honey-like), so I figured starting there wouldn’t hurt. After Googling a few of the recommendations folks here have made over the years I stumbled upon this thread and post over at the Jalopyjournal:
https://www.jalopyjournal.com/forum...ssion-and-differential.1226135/#post-14012718
Basically, there are 3 current specifications, GL-1, GL-4 & GL-5. Other grades that were in existence before have been obsoleted.
GL-1 is pretty much straight mineral oil, with some rust and oxidation inhibitors and foam suppressants. These lubes are for automotive gear sets in transmissions and differentials prior to the development of hypoid differentials (lowered drive shaft that offsets the pinion gear relative to the ring gear). If the differential has a non-offset pinion this is spec is fine. It will also work in transmissions with bronze synchros.
This was the first time I had ever seen GL-1 mentioned anywhere, and man does the description above fix exactly what a Speed Queen transmission is, and heck even a Maytag and most other sealed/splash lubricated transmissions in our vintage machines! A few responses later a contributor mentioned using the 90w GL-1 gear oil from NAPA in their pre-War Ford rear ends, and a few others chimed in as well indicating that they had great luck using similar GL-1 gear oil in pre-War tractor gear boxes, etc. After checking stock at the local NAPA store I jumped in the truck, heading over to NAPA and grabbed a bottle! While waiting for the tech to run the transaction I shook the bottle they had brought from the back and it sounded exactly like a bottle of OEM Maytag transmission oil. I got excited then as I knew what I had just stumbled on to.
After pouring out the MT-90 and cleaning all parts, a fresh pour of 24 oz of the NAPA GL-1 90w oil was added to the transmission. It pours the same as OEM Maytag, is sticky like OEM Maytag, and smells just like it. This was it - the moment of truth. Was the wave I had originally seem with the original oil going to come back to life? Sure enough, it did! The same wave was recreated with the GL-1 oil and the oil level was almost identical to what the original was. I was back in business! I slapped the transmission back together and threw it in the washer. Sure enough, with a tub full of water the agitation stroke of the transmission was a silent as could be!
To answer the earlier question of why, I have a few theories. The mineral based GL-1 oil is “old school” gear oil and the tolerances between the pinion and drive gear in the Speed Queen were intended for old school gear oil and not necessarily fancy new blends of GL-4 or synthetics. For years I was worried of trying to back into using a modern replacement when I should have been looking through the lens of what would have been common place in the 1940’s and 1950’s. Lesson learned!
So, to repeat from the fluid drive fiasco, if you’re working on the transmission of a Speed Queen or Beam related automatic washer, a fresh fill of 24 oz* of GL-1 90w oil is a safe bet. In fact I’ll use the rest of the bottle from NAPA on any future Maytag / GE belt drive / Whirlpool belt drive transmission rebuilds as the GE and Whirlpool specification of 40 weight crank case oil translates nicely over to a 90w gear oil. Varieties from NAPA and Tractor Supply are linked below.
* Hotpoint indicated 2/3 PINT for their Beam transmission which seems awfully low. I’d probably fill 24 oz if rebuilding a Hotpoint non coaxial transmission
https://www.napaonline.com/en/p/NHF65201
https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-2-gal-t806600
Glamor shots and video!
This has been a long winded thread, so for the last post I’ll let the photos and the video do most of the talking. Enjoy!
This was an incredibly fun and rewarding restoration and I truly hope that both will outlast my lifetime and may bring joy to many. While neither are perfect they fit perfectly in the collection and I couldn’t be happier.
There are several members to thank:
Robert - when I first saw your ’58 Speed Queen in the late Fall of 2004 I knew right there and then that someday I needed find a solenoid drive Speed Queen. It was so unlike anything I had ever seen up to that point
Greg - the many SQ washer you’ve found over the years and shared here on AW, PLUS seeing your absolutely gorgeous ’55 Speed Queen during the 2005 wash-in, left a lasting impression on me, an so many others who were there that weekend!
Don - what can I say? While this isn’t a suds saver it certainly is a sister to your beautiful A78. Thank you for the many opportunities to work on and help provide parts to keep your wonderful childhood memory going, all these years.
Ben
What a beautiful set, and what a fantastic restoration on them! The more I learn about what goes on with restoring them makes me appreciate them so much more. With a restoration like this, and a person with your expertise, I do not doubt these machines will continue to run for many years
Ben, that pair of machines was well worth restoring.  They are stunning, and you did an amazing job that should keep them humming and purring along for many years to come.  Congratulations!
Certainly an interesting thread, especially about oils. Looks like GL-1 has been the hidden secret all of this time for most washer transmissions.
Who would have thought that regular 3 in 1 oil would provide superior results in a coupling over the genuine stuff?
Another top-notch restoration. These machines are just stunning, I remember them as a kid at my mom's aunt's house - the lighted panels were breathtaking to a little washer-obsessed boy, surrounded by low-end GE and Maytag Highlanders.
Congrats on a job very well done, your talents for restoration and detail have really risen to the top of the class since we all first met back in '04-'05.
Wow
Breathtaking. One of the most attractive washer pairs ever. I had no idea they ran that quietly when new.
SQ fluid drives in avocado and almond were what the college dorms had in my day in the early 1980s. They had been used nonstop around the clock, abused and massively overloaded, jammed countless times with socks that overflowed, so each one sounded and worked differently — and definitely not quietly and smoothly like that!
They made such a unique splash-splash sound!
What a jewel in a collection. Enjoy!
What a spectacular way to celebrate Monday Washday, Ben. Actually breath-taking. What a glorious Speed Queen, the big lighted dials reminiscent of Blackstone Royalist's. Didn't know about the exuberant double overflow rinse, such a treat, and the vigorous iconic Speed Queen turnover with those steep fins and high-riding vanes.
I loved the free-spinning tub in the first vid. Haven't seen that before, but mind the little girl, LOL.
So much work, not to mention the writing which had to have taken hours alone to accomplish, but knowing your tech genius, there's probably one of those new IA scripting robots doing it for you, (laughs).
You have no equal Ben, period!
WOWZERS...
Those cleaned up amazingly! I love all the options on the washer, wash & rinse temps, agitate & spin speeds. And I have to say, I really enjoyed the added short clip of the agitation with the lint filter accessory attached on the agitator. It made the agitation sound like a different washing machine was chugging away.
Oh man, you did an OUTTA SIGHT restoration on that Speed Queen set. They look brand new!
An honorable Salute to 1967!
Amazing, speed, queen, washer and dryer restoration Ben
I have certainly never had a speed queen washer that far apart from that vintage we have a 1968 middle of the line washer in the museum that we put the 800 RPM spin Poleon but never seem to spend that fast but it was a big improvement.
It’s amazing what you found out about oils, my brother, Jeff discovered back in the 70s that when we had a Speed Queen fluid drive washer that wasn’t spinning fast enough he would take half a bottle of zoom spout oil and squirt it into the clutch and it seem to help a lot.
It’s also amazing what you found out about transmission oil thickness, he’s older transmissions, needed a pretty heavy oil. They weren’t made for light oil, Maytag’s also needed heavy oil. Maytag did not even use helical cut gears like about every other washer so they would have noise issues. That’s why they use the plastic pinion gear to quiet them down a little bit
Yes, getting the transmission out of the Speed Queen was one of the few easy things to do to it, Ge Filter Flow is still the easiest washer to change a transmission in for a vintage machine and of course a newer whirlpool direct drive washer you can change the transmission in 15 or 20 minutes in those .
These old Speed Queen dryers were certainly built like a tank I think only this dryer and the old Norge dryer‘s. You could actually fill them with rocks and could tumble them without harming the machine.
I never felt that the Speed Queen dryers the few that I used were all that fast, but they certainly were built well and they used to be used commercially and they would just go on and on and on
When you do these restorations you should check in with me. I have a lot of new parts for the both the washer and dryer that I would’ve been happy to send you. I think I even have new cans of transmission oil for speed queen washers. I will never use this stuff . The other guy that’s really good with these is Bob Salem in Cleveland. He knows more about Speed Queen washers than anybody else that I know still living except for you now as well lol and he has lots of parts for these that he would be happy to send on to others
Can’t wait to see you tear into that Kenmore combo.
John
Thank you for the kind comments, everyone! I smiled reading through all the comments knowing that the set has made many of you as happy as they have made me.
Henry - When I first found this site back in August 2004 I would marvel over Robert's 1957 Lady K restoration photo guide, and walked through it several dozen times over the following years.  I told myself then that if he could do that I knew eventually I could do the same.  And thus, a passion ensued.
Who would have thought that regular 3 in 1 oil would provide superior results?
Dan - certainly not me, or at least not before I figured out what the actual viscosity of the 3-In-One was.  There are a few pneumatic tool oils that fall in the 15 to 20 range that I would have liked to have tried but time was starting to run out during the testing phase.  Maybe the next collector could give a few a whirl.  You should pick up a bottle of GL-1 90w oil.  I would love to hear your thoughts.
Mike - oh goodness, the time!  LOL  I learned with the Bendix restoration write-up that it is easier and better to write the full thread offline, over the course of several days.  It provides the time to make necessary edits, revisions, and additions, however it appears I would still benefit from a true editor. :)
Christina - I'm so glad you caught that small clip!  The filter dramatically changes the sound, especially for partial loads where the turbulence can be drastic.
John - me too!  There is a basement laundry room restoration and 5 other machines that need small attention before I get into the full teardown of the '71 LK combo.   It's the next big one and I'm looking forward to collaborating with you and John E on that one.
Ben
Hi Ben, as usual great restoration and documenting the restoration as well.
So I was curious after reading what you went through for the spin speed. I just tested my 1952 Speed Queen which also has the commercial spin pulley installed. After about 90 seconds of warm up time (it was the first time it was run in nearly 3 months) it reached full speed of 725.6 rpm. What I remember doing was I simply kept squirting zoom spout oil into the fluid drive until the proper speed was reached. At one point I put too much oil in and it popped the motor protector, so I removed a bit of the oil until the machine worked properly without popping the protector. I have no clue as to the actual amount of oil that in there now.
I would like to do a thorough restoration on my SQ as well and your information will certainly help.
