I personally do not buy the THEORY (Yes, its a THEORY. Not proven in the field) cold water washing, for several reasons:
- When testing institutions 'do it,' they only wash the items once. Not hundreds of times, as a normal garment would. And it is my opinion this biases the result; if cold-water is 8% less effective in cleaning, as our testing institution (CHOICE) claims, then by the time the garment is ready to be discarded, I would bet putting two garments side-by-side would reveal a NOTICEABLE difference in both appearance, and odor.
- My own experience with cold and cool water washing has been that odors are NEVER, EVER fully removed. This is a major problem when dealing with underwear, socks and the like. And in my case, shirts too. I sweat a lot, and cold water just doesn't cut it. I need HOT water, and plenty of detergent.
- I found with our previous washer that clothes washed in cold, and line dried ALWAYS had a "musty" odor to them, something that ceased with the Miele, and warm and hot washes.
- Machines used with cold water do not last. At work, the Butcher's department has gone through no less than 2 front-load washers in the 3.5 years I've worked in the Supermarket.
The recipe? Quick Washes (which usually have GENEROUS water usage, i.e. halfway up the door) AND lukewarm water washes/rinses.
- Has no-one seen the threads here at AW.org where reasonably new washers have been torn down for restoration, and found to be filled with mold, scum and dirt? In almost all the threads I've read, the common denominator has been cold water, perhaps under-loading detergent AND/OR fabric softener.
Should this be inadequate, perhaps some of the folk here who work on washers for a living might like to share their thoughts on cold-water washing...
- It has been stated that the oil in our skin does not dissolve readily into water until about 35°C (90°F) - cold water RARELY, if ever, gets this warm. Unless you live in the Sahara desert, perhaps. If it doesn't dissolve, where do people suppose it ends up? In the drain? In the washer? Back in your clothes?
Now for the quick opinions on running your tap at the dishwasher to HOT before use. I still recommend this:
- If your water is heated with Gas, Geothermal, Heat Pump OR Solar, it saves plenty of electricity (far more than the cost of water) for running the tap, even two or three times. At home, I run the tap twice for the Dishwasher, once at the start, and after 16-47 minutes (depending on the cycle) for the rinses.
Total Electricity Saved Annually = $18* . Total Water Used Annually: <$3.
*When using a cycle with about 25 minutes of heating on tap-cold (about 65-80F, usually). This is reduced to about 10-15 minutes, with a 700w/hr heater. Saving is doubled if the Heaviest cycle is used daily.
If you are concerned about the water usage, get a large bucket, catch the water, and use it for pre-soaking laundry, or watering your garden/pot-plants or whatever you see fit. It doesn't have to go down the drain.
